bhaf= no smoke?
bhaf= no smoke?
Today I removed the silencer ring and put on a bhaf...and removed the oem air box....well.....virtually no smoke.... I was able to puff quit a cloud like at the low end of third.....but now 90% of the smoke is gone.....The plate is stock....I think the previous owner has turn the star? anoid? whats it caled?<br><br>What happened....I m really surprise just an air filter change made a difference....power seems about the same or better by the butt meter....<br><br>sorry no gauges yet.....<br><br>
Re:bhaf= no smoke?
Since the BHAF has less restriction than the stock filter you now have more air than before. <br>To get some smoke back you can turn the AFC starwheel a little. Looking at the inj. pump from the top you see an 8mm allen plug. Remove it and you see the star wheel. Some clicks towards the engine and you have more fuel under low boost. Note the number of clicks you do and turn back if there is too much smoke.<br><br>AlpineRAM<br>
