Batterys bolts
Just buy some threaded rod from the hardware store and cut to length. Be aware, that if the threaded rod is to long or you go with a shorter battery and use the factory battery hold down bolts, they can cause a short in your wiring. There is a harness under the battery tray, right where the bolt goes in, and if they are to long you are in trouble.
As far as cables, there is a recent discussion here:https://www.dieseltruckresource.com/...ad.php?t=82608
dsherman
Aug 18, 2004 11:36 PM
