away from home help
Old Oct 1, 2004 | 02:49 PM
LarryJ's Avatar
away from home help
P1693
I'm away from home and on a borrowed computer so no time to search. Can someone give me a link me a list of the codes or tell me what this one is? thanks Larry
Old Oct 1, 2004 | 03:11 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Is the truck running OK?
This code usually indicates a code was set in the ECM.
Old Oct 1, 2004 | 03:16 PM
LarryJ's Avatar
Ed, it's running fine but we are a long ways from home and wanted to know whether to go ahead and have the family out on the road with it like this. Power is fine, Im pulling about 9K lbs.. Im glad you are on here today, strange how away from home amplifies a problem one is having. Regards, Larry
Old Oct 1, 2004 | 03:53 PM
sherod's Avatar
Where are you at? I'm still learning, but agree with Ed about the companion code. Could it be you have had to WOT a few times with your load? Might have set something with that. If possible, pull in to AutoZone or somewhere and have the rest of the codes pulled. It may have just been a glitch that will take care of itself. Good Luck.
Another Ed
Old Oct 1, 2004 | 03:57 PM
LarryJ's Avatar
I'm in Massachusettes and from what I can read it is a low fuel pressure companion code so should be ok.. I have guages and it never drops below 9 psi so who knows. I wish I knew how to reset the code but Im going to take it home anyways. New fuel filter before leaving home and lift pump sounds ok, shows good fp. Maybe a glitch. thanks all. Im going home
Txwelder
Dec 31, 2011 12:02 AM
jmccart
48
Jul 23, 2008 12:34 AM
Perkio
Apr 9, 2008 08:00 AM
2500TurboDodge
Jul 31, 2006 04:21 PM
Foothill-Trader
Jul 31, 2005 10:04 AM
