autometer drill & tap ?
Old Dec 31, 2002 | 01:24 PM
Garz's Avatar
I'm about to install my pyro & boost gauges. The autometer guys tell me to use 11/32" drill for both when tapping. I see no prob. with the pyro. but the boost fitting is quite a bit larger (like needing to use 1/2" drill). I'm not sure if they understand that my 89 is non-intercooled and will be tapping into the cross over tube from the compressor. Can anyone help me out please. ???
Old Dec 31, 2002 | 02:02 PM
Ruralmedic's Avatar
Re:autometer drill & tap ?
That 11/32 (.343&quot tap drill sounds like it's for 1/8" NPT. 7/16 (.4375&quot tap drill is for 1/4" NPT. If in doubt, check local hardware store for a thread gauge. I know when I installed my pyrometer probe, it was 1/8" NPT. On my ISB for the boost, I just removed the plug on the side of the engine and didn't have to run any threads. Hope this helps. Happy New Year!
Old Dec 31, 2002 | 04:12 PM
RCW's Avatar
RCW
There is no sense tapping the pressure side of the air system. Just go to the top of the intake manifold and pull one of the plugs already installed for that purpose.
Old Jan 1, 2003 | 11:40 AM
Garz's Avatar
Well that makes sense. Some directions I got told me to tap the boost tube. Glad I asked.
Old Jan 1, 2003 | 07:51 PM
99 cummins's Avatar
Where is this plug, I looked on my 99 and I see 3 larger plugs and 1 smaller one on the top of the engine by the manifold. Is one of these what your talking about?
Old Jan 1, 2003 | 08:04 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Check here and see if this helps.<br>Boost install near bottom of page.<br>http://www.showmestate.org/stltdr/ho...T_how_to.shtml
Old Jan 1, 2003 | 11:04 PM
Garz's Avatar
Unfortunately my 89 is alot different, and the only thing I see for a plug looks like a tranny drian plug underneath the manifold (38&quot; insert and a PIA to get to). I pulled out all the bolts on my manifold looking for something and got nothing. Directions I found said to drill and tap boost tube for the 89 and that sounds pretty good about now.
LovinTheTorque
Sep 14, 2013 12:02 PM
glarior
May 17, 2011 07:46 PM
Hoss
Apr 11, 2006 11:37 PM
Moose10
Dec 2, 2004 04:31 AM
Drafter
May 10, 2003 10:51 AM
