Auto transmission, weird shift
Old Oct 28, 2007 | 03:49 PM
Santaclaus's Avatar
Unhappy Auto transmission, weird shift
While driving at 50 mph, transmission was shifting in and out of overdrive, on level ground. Checked transmission fluid, clear, (not milky) overfull with bubbles. Came home let sit for few hours cranked up in neutral, barely overfull no bubbles. Any ideas??
Mike
Old Oct 28, 2007 | 10:22 PM
oldblues's Avatar
Exclamation
hi
prob your tps is acting up !
try unhooking battery and turn on everything for 20 min then turn every thing off and reconnect batt .
turn key to on position slowley press acclerator to the floor and slowely release it ., turn key off .
start and drive .
still not working look up the procdure on cleaning the tps on this sight .
i did mine and it works new agin !
Old Oct 28, 2007 | 10:36 PM
vzdude's Avatar
DTR's 'Go to Guy'
Also could be bad diodes in the alternator, dirty grounds.........several possibilities.
Old Oct 28, 2007 | 10:59 PM
J BODY's Avatar
On a 92 I would want to see what your TPS voltage is at idle. I'm betting it's too low. Like to see .9 to 1 volt. Linkage may be worn. I often remove the TPS, push out the metal screw inserts (where the sensor bolts to the linkage), and drill the holes a little larger. This will give you some "adjustment" when reinstalling the TPS. Sometimes this won't work and you just have to replace it.
Old Oct 29, 2007 | 07:00 AM
Santaclaus's Avatar
Thanks I'll try those things.
Mike
Old Oct 29, 2007 | 08:07 AM
patdaly's Avatar
TPS was what it turned out to be on my 97, tried everything except drilling out the TPS and cleaning it with Contact Cleaner, figured it would screw up when it was -10 out.
Since you live in Fla., you might try doing a search here on cleaning your TPS, could save you some serious dough, and you don't have to worry about subzero weather if it doesn't work.
NICE_N_EEEZ
Mar 22, 2011 04:33 PM
sdubfid
Feb 13, 2009 10:40 PM
Common
Apr 9, 2008 10:25 PM
Tuckerdee
Jan 27, 2008 09:53 PM
yodey44
Jan 8, 2006 01:38 PM
