Access to heater/ac switch?
Old Apr 12, 2005 | 08:15 AM
Livngood's Avatar
Well after a perfect (?) installation of x-monitor and brakesmart the last couple of weeks I happen to turn on the heater/ac to test the ac since I had a small leak last year and found I now only have air coming from only the defrost vents.....with the switch in any position other than off.
So I suspect the vacuum lines might have come off the back of the switch (or electrical lines). Assume it just switches the vacuum to different areas. I know I at least have vacuum to the switch since defrost works. I know it must be related to the under dash mounting and re-zip tieing the wires to the brakesmart or x-monitor.
Question: How do I get to that switch?....Hopefully from the passenger side....Are there screws or do I have to pry off the dash board parts up around that switch?
Help appreciated before I start digging blindly today.
Jay
Old Apr 12, 2005 | 08:36 AM
dieselnut55's Avatar
In my truck 98, the dash bezzel just snapped off. Mine did that when I first got her, and I found the vac disconected down by the pump
Old Apr 12, 2005 | 08:56 AM
Livngood's Avatar
Is the pump up under the dash?
Jay
Old Apr 12, 2005 | 09:32 AM
infidel's Avatar
Jay
No, it's under the hood on the side of the engine with the power steering pump. Most likely you accidently unhooked a vacuum line while feeding wires though the firewall.
Old Apr 12, 2005 | 02:40 PM
Livngood's Avatar
Solved...
Thanks the help. Two hours to trace (my time) no labor charge. Vacuum line (hidden) across and behind the wiring on the firewall area had popped off. Actually, I think the guy who installed my X-monitor pulled it off by mistake. Anyway it's fixed without ripping the dash out! Thanks again for pointing me in the right direction.
Jay
biglar
May 15, 2009 07:39 PM
EQUIPPRO
Apr 26, 2006 03:00 PM
tlea7
Mar 17, 2003 07:46 PM
Mexstan
15
Mar 17, 2003 03:22 PM
mymaur
Feb 24, 2003 07:08 PM
