Abs light brake light and no brake lights
Old Apr 4, 2009 | 01:45 AM
polaris800sp's Avatar
Question Abs light brake light and no brake lights
I have the Abs light and brake light on and also have no brake lights. my blinkers hazards and tail lights still work. also there are no codes so i am confused on where to begin looking to fix the problem. also i was wondering where i could find a wiring diagram for my truck? any help would be appreciated.
Old Apr 4, 2009 | 10:38 AM
infidel's Avatar
You could start by replacing the brake light switch.
I paid $12 for one a Napa last month.
Old Apr 4, 2009 | 03:02 PM
patdaly's Avatar
As for the brake and ABS light, check your Master Cylinder, when the rear brake line rotted out on both my 97's I had the Brake and ABS lights and a hole in the line. You really couldn't tell you had no rear brakes........
Old Apr 6, 2009 | 10:34 PM
I forgot to add that my speedo isnt working also??
Old Apr 6, 2009 | 11:12 PM
clops79's Avatar
sensor on trans and funny looking fuse under hood i fuse box, the same thing happened to me sensor went bad blowing little sqaure fuse and after replacing fuse speedo wouldnt work till after 20 mph and thats how i found bad sensor on diff.
Old Apr 7, 2009 | 10:02 AM
infidel's Avatar
Very important symptom.
ABS depends on communicating the vehicle speed as compared to each tire's speed.
Start by checking wiring or replacing the vehicle speed sensor on your tranny or transfer case if 4wd
Old Apr 7, 2009 | 10:08 AM
hekroh's Avatar
Based on your last symtom, I would change the sensor in the rear differential. These are the same symtoms that I had when mine went bad.. Not sure what it is called, but there are several post about it.. That is how I was able to figure it out.. Quick fix, and relatively inexpensive compared to other things.
Godd luck. and let us know which fixes the poblem..
Joey-D
Dec 12, 2011 12:52 PM
BigBore050
Mar 9, 2010 11:46 PM
polaris800sp
Nov 13, 2008 05:35 PM
sssmaly
Jul 13, 2007 12:57 PM
mr T
Feb 24, 2007 06:42 AM
