Abs &e Brake Light
Abs &e Brake Light
After Recalibrating And Restting My Apps I Did Both.Now My Brake Light And Abs Light Stays On . I TOOK A DRIVE AND IT DROVE FINE AND EVERY THING WORKS .Can Anyone Shed Some Light On This?
Turn the key from off to on 3 times, leaving it on the third time and check for codes in the odometer window.
I had the lights on after resetting my APPS, but that was probably due to the fact that I had the connector on the PCM unplugged while the key was on. The lights went off as soon as I started moving.
Ok I Checked Codes I Have 1687 1693 1694 1698 0236 0237 But Think I Got These Codes When I Accidently Started Up My Truck With The Comp Box Unplugged .and What Do You Have To Do To Reset These Codes?
Yup all 3 of those sensors are gone on my truck. Put the scan tool on it the other day at school and those 3 came up. I'm not really too worried about it because well, don't need ABS.
Joey-D
Dec 12, 2011 12:52 PM
mr T
Feb 24, 2007 06:42 AM
