98 12V Issue
Old May 8, 2007 | 05:53 PM
CIN'S DODGE's Avatar
Mrs. missin on a mission & keeper of the can
98 12V Issue
Need help. My O/D keeps kicking in and out. Already set the TPS and bought a new brake switch. It's still doing it between 60-75 ALOT. What could it be ? Could it be my Torque Converter?
Old May 8, 2007 | 06:04 PM
schoust's Avatar
Could be the solinoid in the valve body or maybe the switch it self is shorting or the wiring to the lock up clutch?
Old May 8, 2007 | 06:06 PM
Gotlift01's Avatar
It's probably noise interferance in the line causing the converter to lock and unlock. I know my truck as well as a lot of others has done the same thing. I used aluminum foil and wrapped the wire going from the alternator to the passenger side battery and that fixed it. Might want to try it and see what happens.
~Nick
Old May 8, 2007 | 06:09 PM
I am taking the truck back to them in the morning.
Thank you Shoust!
Old May 8, 2007 | 06:14 PM
How is it that it has interference? I am open to any and all suggestions. Thank you!
Thanks Nick!
Old May 8, 2007 | 06:18 PM
Gotlift01's Avatar
I dunno what causes it, but for some reason they get some weird noise that causes it to do it. DTT makes a noise filter for this exact problem.
~Nick
Old May 8, 2007 | 06:32 PM
Totallyrad's Avatar
A long wire is the same as an antenna. A long wire being moved by an engine running at a certain speed can cause the wire to generate a wave signature which is picked up by the wire and can confuse certain electrical components. I don't know if that's it, but it sounded good.
Old May 8, 2007 | 07:10 PM
ratsun's Avatar
Yep
According to BD the noise is picked up from the charging system?
Anyhow the noise filter is cheap and does work. As said insulating the wire would probably do the same job? On your truck its the orange wire with the bark blue tracer coming out of the right hand (closest to the engine) block out of the PCM
Old May 8, 2007 | 07:29 PM
okay guys, we have 2-orange wires w/dark blue tracers coming out. Which one is it? Anyone know?
Old May 8, 2007 | 07:35 PM
Totallyrad's Avatar
Where do they go Cin?
Old May 8, 2007 | 08:02 PM
They go into the cluster along the firewall
Old May 8, 2007 | 08:06 PM
Totallyrad's Avatar
Did it look like either one goes to the tranny? If so, I'd start with that one if you're going to do the foil wrap.
Old May 15, 2007 | 04:48 PM
Okay here is an update on my truck.Don't know exactly if this was the issues or not but it is not doing it anymore. My vacuum hose had like a little melted spot in it, and the ground wire that they put on my TPS to the battery was not tightened up all the way. Thanks to my husband going over things with a fine tooth comb. . Cin's all happy again.
Old May 15, 2007 | 05:11 PM
b.lee's Avatar
I got my noise filter from goerend for free.
free shipping and everything... nicE!
Old May 15, 2007 | 05:16 PM
mr T's Avatar
http://www.tstproducts.com/Torque%20...p%20Switch.pdf
adjust ur brake switch if that hasn't been done....and install the swicth so that u have the option of maintaing lock-up on the highway....pm me if u have issues
