96 4x4 death wobble has returned
Old Feb 29, 2008 | 03:24 PM
Ramdriver15's Avatar
Dont know why but the death wobble has returned.
Recently with in 6 months replaced:
- Passenger outer tierod.
- passenger wheel bearing
- (2) Steering boxes
- Steering shaft
- Steering stablaizer shock
- Pitman arm
- Control arm Bushings
- shocks
- Brand new tires
- Checked tierods, no play
- 2" leveling kit
-New pads, calipers
- 4x4 u joints (started after replacing passenger u joint)
- axle seals
Im lost for words... the shocks are not made for the leveling kit, could this be the issue?
Old Feb 29, 2008 | 03:45 PM
TIMMY22's Avatar
1. Check play in Track bar.
2. Check for play on sway bar links rocking truck back and forth.
Old Feb 29, 2008 | 03:53 PM
JIT's Avatar
JIT
Thats where I would start as well!
Old Feb 29, 2008 | 03:59 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Mine returned also....Also replaced a bunch of parts....Going to have the alignment checked.Maybe thats what went out.
Old Feb 29, 2008 | 06:53 PM
alignment and also new track bar were installed, and tierods... ball joints are all new also...
Old Feb 29, 2008 | 06:58 PM
Alphacowboy's Avatar
Check the bolt on the axle end of the trac-bar. it has to be very very tight! Make sure that sucker is super tight.
Old Feb 29, 2008 | 07:08 PM
1 grumpy's Avatar
what about if the steering knuckle bolt's are loose or if the end where the steering arm bolts to the knuckle is egg shaped.
My ford's steering ball joint had been loose and it had wobbled around and made the hole egg shaped.
When you figure it out let us know
Old Feb 29, 2008 | 07:20 PM
checked the track bar bolt first this morning, it was tight as heck... i used a 3 foot long 1/2 in. drive ratchet... the bolts to the back of the knuckle that attached the hub are tight as well, and also the ball joint holes in the knuckle are "normal" and tight...
hmmmm, could it be the leveling kit?
Old Feb 29, 2008 | 07:56 PM
TIMMY22's Avatar
Did you check the sway bar links?
Old Feb 29, 2008 | 09:12 PM
sway bar should have nothing to do with death wobble.
After you installed the leveling kit, did you adjust the cambolts on the lower arms? You need adjust these, as it will throw off the alignment. Plus, your front tires should be ever so slightly toed in, whne you install the spacers it will changed the angle of the axle, and can cause your toe to be off.
Old Feb 29, 2008 | 11:49 PM
truck was aligned and castor bolts are maxed forward, that seemed to cure it last time
Old Mar 1, 2008 | 10:46 AM
Dave Miller's Avatar
Does it "death wobble" when hitting brakes. Reason I ask..I had replaced lots of the mentioned front end parts chasing death wobble for 2 years and finally it started shaking real bad when just touching brakes. I replaced rotors and its been gone 3 months now. Rotors were obviously cracked and probably warped.
I think my rotors were bad all along but not enough to suspect rotors till they were really shot.
Old Mar 1, 2008 | 07:05 PM
Common's Avatar
I doubt the sway bar would have anything to do with the DW.
I took mine off of my lifted '95 2500.
Old Mar 1, 2008 | 07:27 PM
TIMMY22's Avatar
[QUOTE=Alphacowboy;1973688]sway bar should have nothing to do with death wobble.
Mine links were wore bad causing a death wobble. Also it caused a much rougher ride and poor handling in the turns. Replaced them and what a difference.
Old Mar 2, 2008 | 12:28 PM
brand new links when all work above was done... they seem a little too long but the death wobble started after that. i replaced most the parts above because i found a bad tie rod and decided to thoroughly check the front end, then when i changed the 4x4 ujoint it suddenly started.
