'92 CTD wont start
Old Sep 4, 2008 | 01:51 PM
new2meCTD's Avatar
'92 CTD wont start
On the way home yesterday the truck started to sputter and die out when I stepped on the throttle. Low speed was fine but would occasionally stumble. I figured that the lift pump went out again. I replaced it a few weeks ago. I went and bought an inline electric pump and installed it. Still the sam problem so I changed my fuel filter. Now it won't start or if it does it won't stay running! Help! This is my only transportation!!
Old Sep 4, 2008 | 02:48 PM
winkle's Avatar
You need to reprime the fuel system. On mine which is a '96 there's thumb pump right below the fuel filter, I just pump it til I feel the pressure build up and then start the truck (it may take a few time of pumping). The other way is loosen one or two of the injector lines at the injector and turn the key on and let the pump run until fuel comes out and then retighten the injector lines.
Old Sep 4, 2008 | 03:23 PM
new2meCTD's Avatar
Bled the entire system already. Primed to the filter, then to the pump inlet, then the injectors. No Luck so far.
Old Sep 4, 2008 | 04:09 PM
Check to make sure that the shutoff solenoid has power when the key is on.
Old Sep 4, 2008 | 05:05 PM
new2meCTD's Avatar
Wanna,
Thanks for the pointer. Don't know why I didn't think to look at that.
The wire was broken internally.
Txbigfoot
May 2, 2013 09:07 PM
corn binder
Feb 11, 2011 09:06 PM
Stroked-Z
Oct 4, 2008 11:28 AM
blazinchuck
May 10, 2007 08:09 PM
qcstunter
Jan 9, 2007 04:10 PM
