911 on side of road broke
Old Aug 15, 2004 | 03:20 PM
ta3834bbl's Avatar
code P1690 and check engine is on. What is the abreviation of CKP sensor?
Old Aug 15, 2004 | 03:30 PM
cumminsboy's Avatar
Crank Position Sensor, good luck on your truck. cumminsboy
Old Aug 15, 2004 | 03:35 PM
ta3834bbl's Avatar
Thanks, I kind of thought that was the bad news but wasn't sure. Where the heck is it and do you think a dealer would stock it? Thanks for the reply. I just left Mopar Nats outside of Columbus Ohio and got about 2 miles, luckily, there is a friend locally that is letting me park it there to fix it. I'm only about 6 hours away from home!
Old Aug 15, 2004 | 03:48 PM
AlpineRAM's Avatar
P1690 is a companion code- just says that there's another code in another computer.
How did you come up with the CPK ?
AlpineRAM
Old Aug 15, 2004 | 03:57 PM
ta3834bbl's Avatar
The code p1693 comes up with the engine lt on when you do the key check thing. we had one of those engine tuner programmers and hooked that up to the plug under the dash and got p1690 only. The booklet for the reader says CKP sensor doesn't agree with the PCM ckp sensor.
Old Aug 15, 2004 | 04:03 PM
phox_mulder's Avatar
AlpineRAM
1693 is the companion one.
P1690 Fuel injection pump CKP Sensor Does Not Agree With ECM CKP Sensor
I'd interpret that to mean the timing has slipped in the injection pump.
phox
Old Aug 15, 2004 | 04:08 PM
ta3834bbl's Avatar
How would that be possible?
Old Aug 15, 2004 | 04:12 PM
It's not, would mean the VP44 is damaged.
phox
Old Aug 15, 2004 | 04:14 PM
AlpineRAM's Avatar
Oopsie- sorry, got that one wrong
Either a timing has slipped or IMO more probably one of the sensors is bad. I'd say you should hope that it's the ECM's CPK that's gone out and not the one in the inj. pump.
AlpineRAM
Old Aug 15, 2004 | 04:17 PM
Yes, hopefully what Alpine said.
A lot cheaper to replace the sensor.
phox
Old Aug 15, 2004 | 10:49 PM
J BODY's Avatar
Unless you have a really early build I believe the 01's DO NOT have a crank sensor. I know my 01.5 doesn't. I thought they got rid of that in 2000 (if your curious it's located behind the starter for those equipped). I believe the ckp is caluculated from the cmp, but basically comes down to the VP and ECM are not seeing eye to eye. Diag comes down to checking fuel sync signal circuit for open or short to ground. That leaves the ECM or the VP at fault. My money is on the injection pump.
Old Aug 16, 2004 | 08:51 AM
ta3834bbl's Avatar
Well, the truck was built 1-00, very early 01. We left it in columbus Oh. at a dealership. I have to call them this morning and see what they say. Nothing like leaving your truck at a dealer 6 hours from home at their mercy!
I will let you know what becomes of it.
Old Aug 16, 2004 | 05:44 PM
ta3834bbl's Avatar
update from Dodge
Well, I got the call from the Dodge dealer. The fuel filter was plugged and had metal shavings in it. They changed that and checked the psi on the transfer pump. Only 10 psi. 950 bucks for the filter, diagnose, and lift pump / install. Then , hopefully the inj pump will be ok. gee, I hope so!
Oh, I almost forgot. I called Chrysler customer care and they didn't! It has 114000 on it, and only 4 years old. Said no recall or warranty extension on the pumps even though they know darn well they have problems with quality on them.
Old Aug 16, 2004 | 07:02 PM
Dieseldude4x4's Avatar
WOW.............
I'll quit my job and change lift pumps all day long for that price.
That's only about $700 profit, not a bad turn around.
Old Aug 16, 2004 | 07:47 PM
ta3834bbl's Avatar
Yeah, but it's 6 hours away. I called napa- 179.00 , local diesel shop had one in stock for 190.00. But just in case it is more than that, I will have Dodge fix it.
I am having second thoughts about that, I should buy it locally, change it out there and drive it home. It might be too late already.
