9.6 mpg
Old Jan 17, 2004 | 12:03 PM
phox_mulder's Avatar
Originally posted by lawnpro
the air filter has a lot of bugs and crap in it so I will probably replace that to. Guess ill search to see how to replace the fuel filter. If I get a bhaf will I have any warranty problems?
Debate still open on that.
There is an TSB regarding "aftermarket" air filters.
They don't mention the BHAF, it leans more towards oiled filters.
I have had mine into the Dealer for 2 oil changes since I got mine, and they didn't say anything about it,
yet.
phox
Old Jan 17, 2004 | 12:08 PM
lawnpro's Avatar
I spoke to the service manager yesterday because I wanted this looked at and he said he didnt know much about diesels and said he called a freind of his and then suggested I try a k&n but I hear to much bad about them.will I like the bhaf or should I just get a stock filter
Old Jan 17, 2004 | 12:17 PM
MnTom's Avatar
I don't think it is your air filter. If it was you should be seeing lots of smoke. I was wondering, have you been following the thread over in the 24v forums about the same thing? Have you checked the fuel pressure? I also wonder about the possibility of an electrical issue. These trucks should get a lot better mileage than what you are getting. I still wonder about the no the no codes. Seems like it should have thrown a code somewhere. What kind of mileage do you calculate by hand? Does it agree with the display?
Tom
Old Jan 17, 2004 | 12:25 PM
lawnpro's Avatar
im getting about 1mpg difference manually calculating napa doesnt have the bhaf in stock so im going to try the fuel filter the crankcase bottle is nasty on the outside so I dont think the thing has been maintained very well there doesnt seem to be any scratches on the plastic cover on the fuel filter either
Old Jan 17, 2004 | 03:59 PM
lawnpro's Avatar
put the fuel filter in and cycled the pump 4 times it sounded like it was spinning fast and no start did it about 10 more times and about had a heart attack when it wouldnt start ran it again and opened the water drain and fuel was going through did this a few times then the pump sounded like it was struggling but it started running thank god. Is this a bad lift pump or did I do it wrong ill let you know if the mpg gets better
Old Jan 17, 2004 | 04:30 PM
MnTom's Avatar
Sounds to me like you really need to check your lift pump pressure.
Tom
Old Jan 17, 2004 | 06:14 PM
lawnpro's Avatar
Smile
reset overhead and its up to 12.6 in stop and go traffic
drop in filter I got from napa has a foam prefilter tacked onto the bottom do I need that because the turbo got a lot quieter when I put it on bhaf is next filter
Old Jan 17, 2004 | 06:18 PM
MCummings's Avatar
Merrick
Old Jan 18, 2004 | 06:28 AM
propinc's Avatar
I would hope the Napa one it fits tight on the shaft ..... like the old one you took off
bngcustoms
45
Jun 20, 2009 06:55 PM
richard
26
Sep 6, 2007 01:35 PM
bigfish5
Sep 19, 2006 12:56 AM
Maddog
Jan 3, 2003 10:01 AM
rshelton88
15
Dec 22, 2002 09:40 PM
