9.25 axle wheel is hard to trun
Ok so while lifting my truck, A friend of mine casued my truck to roll off the jack stand. luckly no one was near it and a jack kept my truck from falling on the ground.
So after its all back together I take it for a test drive and find there is a weird off and on hum cumming from the driver side at 50mph+
When I got home I checked everything and what I found were the driver side front wheel doesnt spin freely and takes more effort to spin the wheel. I also found a scuff on the rotor which leads me to believe the rotor did hit the ground.
My tec friend thinks its just the wheel bearings but i feel no play when I wiggle the wheel.
what parts could I have damaged by that rotor hitting the ground?
The wheel should not be harder to turn than the right side wheel under same condition. Axle disconnect in 2 hi. If rotor hit ground could easilly damage rotor. Don't believe would damage bearing, however. Could something have hit the caliper and bent brackets? Could you just have a caliper starting to hang up causing drag and noise?
Thanks for the replies, I dont think the rotor is damnaged because, its equally hard to spin the wheel thruogh the whole rotation. Ill be to busy to look at it for a few days but will report back.
Thanks again
Thanks again
Dargo
Jan 12, 2018 07:45 PM
roxxx
Apr 13, 2009 05:15 PM
rjm022
Apr 18, 2007 09:44 PM
ridofpwrstroke
Aug 25, 2006 05:24 PM
