4X4 Not working!!!!!!!!!!!!!!!
Old Dec 4, 2008 | 07:49 AM
ram 2500's Avatar
I have a 2000 Dodge ram 2500, I use the truck for snow plowing so i NEED
4X4!!! When i put the truck in two 4X4 the light comes on then whe i drive the back tires will spin and there i a grinding sount that comes from the transfer case!!! Has any body had this problum?????????????
Old Dec 4, 2008 | 08:12 AM
cheadlesram2500's Avatar
I have had my 4x4 grind just a little bit when i put it in low. But its never done anything else than that. check the fluids.
Old Dec 4, 2008 | 08:21 AM
chariotdriver's Avatar
Thoughts
The light only tells you the CAD is connected which means the vacuum switch on the transfer case is doing it's job. (I think the 2000 is the same as the ones I have) Make sure the transfer case shifter isn't loose (it has 2 big mounting bolts on the side of the case) like you may be in between 4 high and Neutral or something like that. As mentioned, try 4 low. It sounds like you may have went into or part way into neutral. cd
Old Dec 4, 2008 | 08:47 AM
ram 2500's Avatar
It works better in 4low but when I accelerate it feels like it is slipping in and out of 2wd and 4X4.
Old Dec 4, 2008 | 09:41 AM
74dart's Avatar
It could be the snap ring in the back have you checked that yet. I have included a drawing in this post. It is #27 if it breaks it will allow the mainshaft to mof back and forth. If you take off part #46 you should see it holding the mainshaft in the bearing. They are only a couple of bucks at the dealer most of them have them on the shelf. I hope this helps.
Old Dec 4, 2008 | 09:48 AM
74dart's Avatar
This one might help as well. It is #31 on this one. Once part #36 is removed then the snap ring can be acessed.
Old Dec 5, 2008 | 08:59 AM
ram 2500's Avatar
HAHA funny i checked it and there was 0 fluid left in it
Old Dec 5, 2008 | 09:37 AM
klx650a2's Avatar
So, does it work better with fluid in the transfer case? If it does, you got EXTREMELY lucky..
Old Dec 5, 2008 | 10:58 AM
ram 2500's Avatar
no it doesn't work any better, i don't think that it would be a bearing.
Old Dec 5, 2008 | 06:54 PM
74dart's Avatar
I just fixed the same problem in mine today. I had a slip ring on the front output shaft go bad that allowed the chain to move breaking the oilpickup tube. The lowrange neutral shift fork was bad. When I bought the new one at TCE they said running it without oil would cause the problem. It had almost ate through the shift fork. It wasn't a bad job but it took most of the day. on the first pic it is part 37. I paid $40 for it but now it is working.
Old Dec 6, 2008 | 12:47 AM
ironbrew's Avatar
I had this and it was the yoke from the vacuum pot to the axle. Bent. Needed the whole assembly. I hate this method of 4X4... Would love to have the old manual hubs, but... too expensive to retrofit... Prior to that, it was a weak vacuum pot (ie - years prior).
Sleigher
May 4, 2017 02:12 PM
PG4x4
Sep 1, 2007 07:26 PM
V.R.Wheeler
Aug 4, 2007 01:00 PM
4doogie
Mar 8, 2006 11:36 AM
candndelivery
Dec 12, 2005 05:14 PM
