2nd gen 12V throttle sticking
Old Aug 3, 2006 | 07:10 PM
Tracey's Avatar
I removed all the cables and linkage. It's not sticking on the linkage pivot on the front of the engine but is sticking back were it rotates near the middle of the block (or end of the pump). It sticks at about half throttle. It moves fine after the half throttle position and before the half throttle position. Is this the pump itself?
Any ideas?
Thanks
Old Aug 3, 2006 | 08:31 PM
mr T's Avatar
sorry need more info...u mean the cable is just stuck? ur pedal stuck? or do u have a hesitation at a certain rpm?
Old Aug 3, 2006 | 09:55 PM
Tracey's Avatar
I pulled all the throttle cables/linkage etc. from the pumping system. It's the lever that appears to be going into the rear of the pump. It will move freely to the half way position and then drag really bad, then freely after the half way position. It will not return to the idle position when released. It sticks in the half throttle position.
Any help is appreciated!
Old Aug 4, 2006 | 09:33 AM
infidel's Avatar
When I've encountered this before the pump needed to be rebuilt.
Old Aug 4, 2006 | 09:46 AM
Tracey's Avatar
Howly moly OUCH!
Old Aug 4, 2006 | 09:50 AM
mr T's Avatar
penetraiting oil?? before u rebuild that pump
Old Aug 4, 2006 | 10:18 AM
Tracey's Avatar
I sprayed penetrating oil all over the external area where the shaft appears to come out of the pump. Tyried working it back and forth. No luck so far.
Any other ideas?
Old Aug 10, 2006 | 04:15 PM
Tracey's Avatar
Still haven't fixed this yet. Now I'm being told by others that it might be the govenor sticking..........Any thoughts?
I did a govenor 4K install about 2 years ago. Never had any problem with it.
Old Aug 11, 2006 | 03:09 PM
farmer dave's Avatar
Have you had the linkage replaced before? I know there was a recall out there a while ago because of the throttle linkage. I don't know what exactly what the recall was for though.
Old Aug 11, 2006 | 04:18 PM
XLR8R's Avatar
Infidel is probably right, if the lever is hanging when disconnected from the rest of the linkage - better plan on a new/rebuilt pump. Try some Kroil on the moving parts first, sometimes it'll loosen things up enough to keep going for a while.
Cummins Freak
Dec 24, 2008 08:38 PM
mainer
May 30, 2007 03:54 PM
Russell_d
Feb 25, 2007 09:12 AM
CTD2001
Feb 3, 2007 01:30 PM
