24v not running right.....
Old Jan 26, 2006 | 09:24 PM
blackdiesel's Avatar
Registered
ok well i was driving back from school today and i jumped in my truck and fired er up and took off. i got out on the road and i could tell that she wasnt as responsive as usual. i drove for about 2 or 3 miles and it got progressively worse.
i had it at about 1/2 throttle and it would sputter then catch back up then sputter again. i pulled off the road and cleaned my battery terminals for the heck of it and it still did it.
from an idle i can throttle it and it will slowely and i mean slowely gain RPM's it dosent smoke at all and i had over 15 psi of fuel pressure the whole time. i could tell one time that i should have had 25-30 psi of boost but i only had 7. i got it to the shop and cracked the #3 injector line and i have fuel.
I also reset my APPS with no luck.
only code is p1693
so any ideas?
Old Jan 26, 2006 | 09:34 PM
Registered
vp44 is under warranty. the FP guage stays pegged. And it takes its readings directely at the injection pump.
Old Jan 26, 2006 | 09:37 PM
crobtex's Avatar
I think you may be on the right track, but I would still check the holly blue first.
Old Jan 26, 2006 | 09:39 PM
Registered
it works fine because i have well over 15 psi directly at the injection pump.
Old Jan 26, 2006 | 09:40 PM
crobtex's Avatar
I though you ment pegged at 0.
Old Jan 26, 2006 | 09:51 PM
Registered
whoops, sorry. i ment the other way
Old Jan 26, 2006 | 10:30 PM
Itsmejoe231's Avatar
Did you check the intercooler hoses?
Old Jan 26, 2006 | 10:44 PM
phox_mulder's Avatar
only code is p1693
If you have the 1693 you need to have it scanned for the hidden one.
Often they won't show up with the key on/off method,
and also won't show up with the off the shelf scanners like Autozone or the like have.
The Dodge DRBIII/MDS2 Scantool can actually talk to the ECM, not rely on the PCM to relay the codes.
phox
Old Jan 26, 2006 | 10:51 PM
Registered
theres no smoke at all .if it was no boost I think it would smoke more. it will start and idle fine , step on the go peddle and just slowly biulds rpm's but no power and no smoke at all only code is 1693 and the check engine light is on , sounds like the vp44 but no 0216 code wire is tapped but I sell wood to the service manager at dodge and he winked at me and said he can handle it
Old Jan 27, 2006 | 08:26 AM
need12v's Avatar
Get it scanned. I'm betting po216 is hiding behind the p1693
Old Jan 27, 2006 | 08:58 AM
Registered
proably right, just hard to get it to town at a idle.( 20 miles)
Old Jan 27, 2006 | 09:56 AM
Buckshotmckee's Avatar
I highly doubt it with the wire pierced. Unless you have friends @ the dealer.
Tye
Old Jan 27, 2006 | 12:28 PM
cmckinney's Avatar
I say it's your VP-44. Those symptoms are exactly the same as what I had when my VP went out. As far as the wire being pierced I had mine replaced under warranty without any issue from my local dealer after I spoke with the head diesel tech.
Take it to the dealer and have the VP44 changed out.
-CM
Old Jan 27, 2006 | 02:51 PM
Registered
the vp is not even a year old. corse, that probley dosent matter.
anybody know how to pull the throttle cable off of the APPS? or does the throttle cable have to come with the stupid sensor?
Old Jan 27, 2006 | 05:16 PM
Registered
ok it aint the apps. i reckon ill have to get it to the dodge dealer and have them check it. im beginning to think its the ip too.
