24 Valve Codes?????
Old Apr 2, 2005 | 07:02 PM
MarkSupply's Avatar
24 Valve Codes?????
Hi I have a 1998.5 24Valve dullay, 4x4, 5spd, quad cab, and when it is hot it cranks a good bit before it will start:. I checked the codes they are
P0203, P1689, P1693
I cant find any of them on the net I hope someone can help me I would be very Thankful. Thanks Nick
Old Apr 2, 2005 | 07:12 PM
roysleight's Avatar
P0203 - Injector circuit-cylinder 3
P1689 - No communication between the ECM and the injection pump module
P1693 - A companion DTC was set in both the ECM and PCM
You might check for any loose wiring connections on the ECM. Hope this helps.
Old Apr 2, 2005 | 09:20 PM
MarkSupply's Avatar
Thanks so much, what does the Injector circuit-cylinder 3 mean? I have no Ideal. Thanks for all the info. Thanks So Much Nick
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
StormTrooper
Mar 28, 2005 09:17 AM
