205,000 miles; bad shake on highway. Please reply
Old Jun 23, 2003 | 08:07 PM
j-miller's Avatar
Re:205,000 miles; bad shake on highway. Please reply
I HAD A BAD VIBRATION RUNNING BETWEEN 55MPH TO 65MPH ONE TIME .I REPLACED ALMOST EVERYTHING INCLUDING THE TRANSMISSION 3 TIME'S BECAUSE OF THE VIBRATION. IT WAS LITERALLY CRACKING THE TRANNY CASE ,HERE IT ENDED IT UP BEING THE REAR DRIVESHAFT AND BAD UNIVERSAL JOINTS.IT RUNS FINE NOW.BUT I DON'T RECALL IF THE PROBLEM YOU HAVE IS IN THE FRONT OR REAR OF YOUR TRUCK. GOOD LUCK.....JOHN
Old Jun 24, 2003 | 10:37 AM
antknee's Avatar
Thank you for the advice. My next set of tires, I will change the rims too. I dropped the drive shaft and the joints were fine. For all the miles on my truck, most of the original parts are still intact. I'm installing Lukes Link for my track bar problem. I think most of the shake is from the trac bar.
Old Jun 25, 2003 | 07:22 PM
danshsss's Avatar
If you havent changed the bushings in the leaf springs I would guess thats were alot of the play is,, Get the poly bushings they are way better than the stock rubber stuff,,
Old Jul 3, 2003 | 12:19 AM
moparman2's Avatar
bent rims........
Old Jul 3, 2003 | 01:06 PM
Haulin_in_Dixie's Avatar
As deep as you have gone on fixing this condition you need to get the front or all tires trued. Go to a big truck tire shop and they will cut the tires on the truck so that they are round. You will get better miles on them and eliminate all questions of rims, balance etc. It will probably fix the truck.
EverydayDiesel
77
Jan 27, 2018 02:38 PM
mustangracer
Oct 23, 2007 12:52 AM
sonnys
13
Aug 13, 2007 05:56 PM
ric o'shea
Mar 24, 2007 10:50 PM
Buckshotram
Jan 9, 2006 09:27 AM
