2003 Dodge Hard Starting
Old Mar 23, 2009 | 06:37 AM
12valvedutchy's Avatar
Thanks in advance
Old Mar 24, 2009 | 11:04 AM
offshorextreme's Avatar
Ive Changed My Lift Pump Twice In One Year The New Diesel Fuel Has Little Lubrication. I By Passed My Lift Pump And Added A Fass Pump And Now No More Problems I Have More Power And Better Gas Milage. Oh And Change It Quick Or Its Gonna Mess Up Your Hp Pump And Thats A Pain In The Rear To Change And Cost About 1,000 Rebuilt
Old Mar 24, 2009 | 12:14 PM
stock03's Avatar
Originally Posted by 12valvedutchy
Thanks in advance
Cool thanks. There are so many acronyms I sometimes lose track.
Old Mar 25, 2009 | 04:38 AM
bigtony55's Avatar
Thanks Rockinmlb. Just a question for you guys. If i do have an injector going should i relplace all 6 now and upgrade them 25 or 50 hp or should i keep stock for now until i get a better fuel system to support them. Also Should i stay with a Performance shop instead of a dealer beings that i have no warranty left? TIA opinions are never bad
Id like to know the awnser to this too????
Old Mar 25, 2009 | 06:36 AM
Stock 03- it happens. all you can do is ask. im still learning myself.
Old Mar 25, 2009 | 07:22 AM
FMB's Avatar
FMB
. . . If i do have an injector going should i relplace all 6 now and upgrade them 25 or 50 hp or should i keep stock for now until i get a better fuel system to support them. Also Should i stay with a Performance shop instead of a dealer beings that i have no warranty left? TIA opinions are never bad
I had a stick go bad at about 97.5k miles, dealer replaced that one stick (not all 6) and I've put on about 65k miles since then. I don't have hard start issues as yet.
I'm one of the guys that firmly believes one brand of diesel fuel is different than another, wether it is the particular specs or the care the fuel receives from production through distribution so it doesn't get contaminated. I'm not a "Low Bid" purchaser.
As for Performance Shop vs Dealer, this is something you should check out locally if you can't pull them yourself. Not all Dealers are bad and not all Performance Shops are better than the dealers. If you aren't sure if you can do the work yourself, you might look at a manual in the library, from a friend, or purchase a legal copy from someone like Geno's. You can also do a search and find a write up on how to replace the sticks.
I'll probably pull all 6 this year and send them in to F1 for testing, repair and re-tipping (Mach 1.6 90HP). I have a lot of traveling planned and this is just some preventive maintenance and tip upgrading.
And yeah, if you are running on the original LP, seriously look at upgrading to a Walbro or other good external pump and get a fuel gauge if you don't already have one.
Back to morning brew. . .
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
Jimmy RockAway
Sep 26, 2009 07:55 PM
abc4yew
Mar 15, 2007 11:55 PM
Happy Traveler
13
Dec 8, 2003 05:14 PM
