1991 D250 Electrical Problem
Old Oct 15, 2007 | 08:24 PM
SRich's Avatar
I am trying to help out my friend, here is what he has said about his truck:
"Last week I was confident that I simply needed a new voltage regulator for my truck, and now I have a charged battery but I'm not getting power to anything; Last week the truck would start, now I can't even use the power door locks. My wires look fine so I can't figure out where the disconnect is. If there were a master fuse I'd be looking at it.."
I don't know really if that is sufficient information to yield any useful tips for fixing the problem, so if there is more information, please send me a message or reply asking it.
Thank you in advance.
Old Oct 15, 2007 | 08:36 PM
jonjennpoi's Avatar
As stupid and simple as it might sound check the battery cables and terminals for good connection there does'nt always have to be a big nasty pile of corrosion on top for them to not make good contact. Have a friend with a jeep that was doing the same thing .........hope this helps
Old Oct 15, 2007 | 09:26 PM
2stroke's Avatar
there are "fuseable links comming off the battery + side. those are your main fueses. there is alot more to the charging system on that truck though.
Old Oct 16, 2007 | 03:46 PM
Yep, fusible links. They are all sitting on the fender behind the battery. Look for crispy wires, that'll be the bad ones.
bjaco35
Aug 7, 2015 08:55 PM
samiam4
Apr 15, 2013 10:49 AM
beater
Oct 30, 2010 09:29 PM
mw66nova
May 13, 2009 05:28 PM
