06 won't start
Old Jun 12, 2007 | 01:33 AM
doznfire's Avatar
06 won't start
Just pulled in to vegas to get something to eat and the truck won't start. Push in the clutch and nothing. I think the safety switch for the clutch died. Any way to bypass this thing?? Does anyone know anything about Desert Chrysler?
Old Jun 12, 2007 | 09:18 AM
John Faughn's Avatar
I do not know witch wires but you can do that , more often than not the sw. will be mounted above the clutch peddle , if you find it there , and there is only 2 wires , than put a wire / paper clip in the 2 connectors , start the truck ,
Old Jun 12, 2007 | 12:02 PM
doznfire's Avatar
Well, jumping the wires didn't work. It left on the back of a tow truck to Chapman Dodge. Now my trailer is sitting in the casino parking lot....
Old Jun 12, 2007 | 12:26 PM
bentwings's Avatar
I think I'd look to the starter contacts If jumping the clutch saftey switch didn't get a response. I had this happen a while back. Sometimes you can get the starter to respond by tapping on the solenoid. Sometimes the contacts can stick closed and run the starter untill it burns up.
Lifetime starters are about $200 at Auto Zone and about 30 minutes to install. It takes a 10mm 12 point combination wrench and a small crescent wrench (roughy) to get the battery cables off the starter and solenoid. Be sure to disconnect the battery cables at the battery first.
Possible you can get starter contacts at a auto parts store. I didn't have any luck there however. Otherwise you can get the heavy duy ones here. A bit after the fact but it doesn't hurt to have them available in the glove box.
http://www.fostertruck.com/dodge/
Old Jun 12, 2007 | 12:52 PM
doznfire's Avatar
Has this been an issue on the 06 trucks?
Old Jun 12, 2007 | 04:00 PM
Buckshotmckee's Avatar
Here is a bulletin I found:
NUMBER: 08-021-06 REV. A
GROUP: Electrical
DATE: October 13, 2006
THE StarSCAN(R) FLASH FILES FOR THIS BULLETIN MUST BE RETRIEVED FROM THE INTERNET.
StarSCAN(R) UPDATE CD 6.05 WAS THE LAST CD TO CONTAIN FLASH FILES.
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 08-021-06, DATED MAY 10, 2006, WHICH SHOULD BE REMOVED FROM YOUR FILES. THIS IS A COMPLETE REVISION AND NO ASTERISKS HAVE BEEN USED TO HIGHLIGHT REVISIONS.
SUBJECT:
TIPM Flash - DTC's Indicating Short Circuits In The Wiring On The Trailer Or No Engine Crank With DTC P1277 - Starter Control Circuit 2 Low
OVERVIEW:
This bulletin involves a discussion and reprogramming of the Totally Integrated Power Module (TIPM).
MODELS:
2006 (DR/DH/D1) Ram Truck
NOTE : This bulletin applies to vehicles built prior to April 03, 2006 (MDH 0403XX).
SYMPTOM/CONDITION:
Customer may experience any of the following 11PM Diagnostic Trouble Codes (DTC's):
B166B - Left Trailer Tow Lamp Control Circuit Low. Trailer harness left lamp circuit is shorted to ground.
B166C - Left Trailer Tow Lamp Control Circuit High. Trailer harness left lamp circuit is shorted to battery voltage.
B178C - Left Trailer Tow Lamp Control Circuit Over Current. Trailer harness left lamp circuit is intermittently grounding.
B166F - Right Trailer Tow Lamp Control Circuit Low. Trailer harness right lamp circuit is shorted to ground.
B1670 - Right Trailer Tow Lamp Control Circuit High. Trailer harness right lamp circuit is shorted to battery voltage.
B166E - Right Trailer Tow Lamp Control Circuit Over Current. Trailer harness right lamp circuit is intermittently grounding.
B1667 - Back Up Lamp Feed Low. Trailer harness back up circuit is shorted to ground.
B2215 - Front Control Module Internal (TIPM). An internal fault code counter has exceeded its limit of 250 counts and one or more electrical outputs controlled by the TIPM have been disabled.
P1277 - Starter Control Circuit 2 Low (TIPM). The output feed current to the starter solenoid has exceeded the upper current limit of 75 amps. This may result in a no-crank condition.
DISCUSSION:
DTC's B1667, B166B, B166E, B166F, B178C and B2215:
1. These DTC's indicate that a (hard or intermittent) short circuit to GROUND exists in the wiring of one or more of the TRAILER electrical harness circuits.
2. The TIPM retries the output on each ignition cycle or request (brake or turn signal activation) in an attempt to enable the output in case the fault is intermittent.
3. DTC's B1667, B166B, B166E, B166F, and B178C may occur individually or in combination with each other.
4. For the two over current DTC's, B166E and B178C, the fault is set when the TIPM has detected electrical loads on the circuit greater than 15 amps.
5. If DTC B2215 is also present with one of more of the above DTC's, then this fault code indicates that the 11PM has detected the faulted condition (short) on one or more of the trailer circuits more than 250 times. When detected more than 250 times, the TIPM disables the electrical output (turns off) to the respective faulty trailer circuit to protect that circuit and the system.
6. Short circuits can be intermittent and will require diagnosis and repair of the trailer wire harness.
7. Once the faulty circuit has been repaired, the dealer must use a scan tool to enable the respective trailer circuit that was previously been turned off (disabled) due to DTC B2215.
8. The new TIPM software raises the TIPM circuit trigger point from 15 amps. to 20 amps.
DTC's B166C and B1670:
1. These DTC's indicate that a short circuit to BATTERY voltage (12 volts) exists in the wiring of one of the TRAILER electrical harness circuits.
DTC B2215 - Front Control Module (TIPM):
1. This fault code occurs when the TIPM detects a short (to ground or to battery) on one of the trailer circuits more than 250 times.
2. When B2215 is present with one of the above trailer circuit faults the TIPM will turn off (disable) the respective faulty trailer circuit or circuits.
3. This internal fault DOES NOT mean that the TIPM module is defective.
4. The TIPM memory can be cleared, this action will turn on a previously disabled trailer circuit. If possible, the fault in the circuit should be repaired first before clearing the TIPM memory.
5. DO NOT replace the TIPM without first attempting to clear the 11PM memory.
6. The dealer will need a scan tool to clear the TIPM memory.
7. If one or more of the TIPM outputs are disabled due to one of these conditions, normal operation can be restored a maximum of five (5) times.
8. The TIPM will be rendered inoperative on the sixth attempt to clear the TIPM memory. At this point the 11PM must be replaced. The DTC(s) that indicates the problem and DTC 2215 will both remain ACTIVE. Neither fault code will can be cleared at this point.
DTC P1277 - Starter Control Circuit 2 Low (TIPM):
1. The TIPM monitors the output current to the starter solenoid for over-current conditions.
2. The DTC is set when the output current to starter solenoid exceeds 75 amps.
3. On trucks equipped with a diesel engine, there may be times in cold climates when it is normal for the starter solenoid current to exceed 75 amps.
4. If DTC B2215 is present in addition to DTC P1277, then a starter solenoid circuit over-current condition has been detected by the TIPM module more than 250 times. At this point, the circuit to the starter solenoid is turned off until the TIPM memory is cleared.
5. The new TIPM software raises the TIPM current trigger point for DTC P1277 from 75 amps. to 100 amps.
DIAGNOSIS:
If any of the DTC's listed above are present, perform the Repair Procedure.
NOTE :The Repair Procedure (TIPM flash) currently can not be performed using the StarMOBILE(TM) in its STANDALONE mode. Use the StarSCAN(TM) to perform the Repair Procedure, or use the StarMOBILE(TM) in its CONNECTED mode to perform the Repair Procedure.
SPECIAL TOOLS / EQUIPMENT REQUIRED:
REPAIR PROCEDURE - USING THE INTERNET TO RETRIEVE THE FLASH FILE:
NOTE :Before performing this Repair Procedure, the operating software in the StarSCAN(R); must be programmed with software release level 7.02 SPI or higher. The software release level is visible in the blue header at the top of the StarSCAN(R) screen.
NOTE :The StarSCAN(R) diagnostic scan tool fully supports Internet connectivity. However, to take advantage of this feature you must first configure the StarSCAN(R) for your dealership's network. Make sure the StarSCAN(R) is configured to the dealership's network before proceeding. For instruction on setting up your StarSCAN(R) for the dealer's network refer to either:
"DealerCONNECT > Service > StarSCAN and StarMOBILE tools > Online Documentation", or refer to the StarSCAN(R) Quick Start Networking Guide. The StarSCAN(R) Quick Start Networking Guide is also available on the website under the "Download Center".
NOTE :If this flash process is interrupted/aborted, the flash should be restarted.
1. Open the hood and install a battery charger. Using a voltmeter, verify that the charging rate provides 13.2 - 13.5 volts. Set the battery charger to continuous charge. Do not allow the charger to time out during the flash process. Remove the charger from the battery when the flash process is complete.
NOTE o not allow the charging voltage to climb above 13.5 volts during the flash process.
2. Connect the CH9410 StarSCAN(R) ethernet cable to the StarSCAN(R) and the dealer's network drop.
3. Connect the CH9404 StarSCAN(R) vehicle cable to the StarSCAN(R) and the vehicle.
4. Power ON the StarSCAN(R).
5. Select "ECU View"
6. Touch the screen to highlight the TIPMCGW in the list of modules.
7. Select "More Options"
8. Select "ECU Flash"
9. Record the part number at the top of the "Flash TIPMCGW" screen for later reference.
10. Select "Browse for New File". Follow the on screen instructions.
11. Highlight the appropriate calibration then select "Download to Scantool".
12. Select "Close" after the download is complete, then select "Back".
13. Highlight the listed calibration.
14. Select "Update Controller". Follow on screen instructions.
15. When the update is complete, select "OK".
16. Verify the part number at the top of the "Flash TIPMCGW" screen has updated to the new part number.
NOTE ue to the TIPMCGW programming procedure, a DTC may be set in other modules (PCM, TCM, BCM, MIC, SKREEM, etc.) within the vehicle, if so equipped. Some DTC's may cause the MIL to illuminate. From the "Home" screen select "System View". Then select "All DTCs". Press "Clear All Stored DTCs" if there are any DTCs shown on the list.
POLICY:
Reimbursable within the provisions of the warranty.
Old Jun 13, 2007 | 02:16 PM
doznfire's Avatar
Thanks Tye! Made it home around 1am this morning after the dealer reflashed the computer. They said it was just a computer glitch and I shouldn't have any other issues now. We shall see.
Old Jun 13, 2007 | 03:28 PM
Good to see ya made it back buddy!
Subliminal
Dec 15, 2010 04:35 PM
ado2b1
Dec 16, 2008 03:19 PM
Machinos
Mar 16, 2008 01:34 AM
