06 squealing wheel, broken studs
Old Jun 16, 2010 | 03:22 PM
06 ky diesel's Avatar
ok, studs are easy to replace, had 2 on passenger side front and one on driver side front. i think the tire shop cranked too hard on the lug nuts when i had bigger tires.
passenger side sounds like wheel bearing going out, truck has 65,000 miles, is this normal? any help or pointers? gonna pull wheel tonight
also, sometimes truck feels like 4 wheel drive is still engaged. truck has shifter in floor, any ideas?
Old Jun 16, 2010 | 04:16 PM
Bark's Avatar
Probably not it but when my front axle u joints were going (at 70k), the truck would sometimes have that 4 wheel drive "lope".
Old Jun 17, 2010 | 07:06 AM
not the bearings, sounds like a rubber bushing, only makes noise on turns. does this sound like the u joints?
Old Jun 17, 2010 | 04:53 PM
Bark's Avatar
Mine really did not make much noise. The "loping" was only really noticable in a left turn. It was my left u-joint that was shot but I had them both changed.
This older post sounds a little like what you have.
https://www.dieseltruckresource.com/...=wheel+bearing
enafzige
19
Feb 28, 2011 09:37 AM
77machomopar
Nov 30, 2009 11:55 PM
Roggie
Oct 12, 2008 09:58 PM
90dodge
May 6, 2008 07:11 PM
What a load
Feb 8, 2005 08:28 AM
