06 2500 5.9 48re quit pulling
My son an i were on our way home an the truck would not shift it was as if the converter was slipping . Then we increased the rpm an trk came up to 55 mph then nothing we stopped you don,t feel it bump into gear in any gear .
Popped the hood the fluid is way up on the stick like one might find if the trk had been sitting for a day or so. The fluid wasn,t overly hot . I,m thinking
maybe the pump has failed what say you ?
We had it rollbacked too Dodge Dlr. There trans man was off today
but when we started it today it would move itself but there was a
fine racheting sound from the trans.
If you held the brake an raised the rpm it would try to pull then lose
out and go to nothing , then it would gradually come back . But it would never just bump into gear an pull .
Little up date transmission was definately out of commision . The total cause not sure yet . The main thing with an issue seems to be the front drum they can,t get it apart . The clutch pack in trans houseing shows some signs of heat
but but all clutch material still in tact . The front band worn pretty bad an the drum shows wear since most of the friction material is gone from the band . Overdrive clutches look look good worn some but no failure . Too me its as if the front
band friction material went away an from it not working right it stressed everything else . Does that drum not stop or slow while the other clutches engauge ? An if its not working right it over works everything especially those clutches in that drum . Anyway the third party warranty people are trying to figure out what they are going to do . The dealer wants to install a new unit . This third party i,m talking about is the exstended warranty he was sold when he purchased the truck new .
dodgeboy59td
23
Apr 23, 2007 10:50 PM
mullercarl
Competition / Pulls / OffRoad
45
Mar 19, 2007 10:10 AM
mx261
Feb 13, 2005 08:32 PM
