05 Blew Up!
Old Aug 15, 2007 | 06:13 PM
TonyB's Avatar
Just read another post about that!
HTH
Tony
Old Aug 15, 2007 | 09:24 PM
dodgge1ton's Avatar
Did you have it torn down yet? The guy i bought mine from had a message from dodge saying some oil filters break down. The filter medium then makes it way to the piston oil cooling nozzles the wrist pin. They lube the pin and cool the bottom of the piston.
Scott
Old Aug 16, 2007 | 12:09 AM
J BODY's Avatar
Chrysler service contract?? or something else.
Personally I don't know of a writer or parts department that WOULDN'T want to make that sale (yes, even though it's contract it still shows on the bottom $$$ line). Of course the tech will have to hustle to make that 9 hours (most likely take it up the whaazooo). If it's an aftermarket contract I can almost guarantee that you will end up with a used engine with "similar" miles.
Old Aug 16, 2007 | 01:14 AM
LOGAN's Avatar
Muted User
chrysler can use their master scanner to tell exactly what that truck has done, when it done it and how it done it, dealer can't do it, chrysler is the only one that can and the only one that will if pending a lawsuit worth money. your case might not be worth their while but i would definately have a cummins certified technician look at it and get written statement from him on the damage and what could of caused it, even evidence from people on the internet with similar problems could help, and get a lawyer.
Old Aug 19, 2007 | 01:21 PM
birdog's Avatar
DM-
What does EJWA on your profile mean?
Old Aug 22, 2007 | 12:10 PM
dmscumnz's Avatar
Well I contacted Cummins about my situation. They asked what filter I was running. Went to the shop and checked the filter # on the truck. Called them back. They took a deep breath and said that they have had a few problems with the Cummins filters coming apart and clogging the oil galleys and paths. Interestingly enough, even when the motor came apart but was still "running" it had plentiful oil pressure... They said it could keep pressure if a filter particulate was hung up in a lubrication supply to a rod or crankshaft bearing - because it would not compromise the rest of the oil circulation. So... I asked them if this was indeed the case what THEY could do for me. Of course, its catastrophic and they can "do absolutely nothing". Blah blah blah!
Old Aug 22, 2007 | 03:04 PM
dmscumnz's Avatar
Ejwa-edge Juice W/ Attitude
Old Aug 22, 2007 | 03:58 PM
patdaly's Avatar
DM, what filter were you running?
Did I read that right that they have CUMMINS filters coming apart?
I gotta know the number now man.......... And is there any other info regarding your warranty?
Old Aug 22, 2007 | 05:23 PM
birdog's Avatar
You mentioned that you never had a programmer on the truck... I assume you had it taken off before your took the truck in.
Did you end up with a warranty issue??
Old Aug 22, 2007 | 06:38 PM
dmscumnz's Avatar
This particular truck has never had a programmer. My other truck (in my signature) has Edge Juice w/ Attitude on it. Both trucks I use for my business. But had more problems ALWAYS with the bone stock truck! ! ! !
I'm currently not at home where I have the filter number written down. Cummins told me to just replace the filter now because the possibly troublesome filters have been removed from the market (too late in my case - guess they didn't understand the fact that I was telling them the motor CAME APART). I'll get the # for ya and post it when I have access to the number.
Old Aug 22, 2007 | 09:39 PM
03qclb5spd's Avatar
better call your Lawyer and get them to honor your warranty
Old Aug 23, 2007 | 11:42 AM
TonyB's Avatar
Ditto! They are conceding to an issue that was catastrophic to your truck!
Old Aug 30, 2007 | 06:40 AM
tornado's Avatar
I would contact cummins again about this issue and try to talk to somebody else about it. I believe they have replaced other engine for this very same thing.
Old Aug 30, 2007 | 07:04 AM
TreeFarm's Avatar
Do we know who made those Cummins filters? Just tell me it wasn't Wix.
Old Aug 30, 2007 | 03:36 PM
tool's Avatar
I thought those were Fleetgueard Filters????
