04 drive line or rear end prob, please help!
Old Jul 15, 2007 | 07:27 PM
bsj04's Avatar
i noticed my truck seem to have a bind or something when coasting down a hill. it seems to be a little worse the slower i get. i tried checking to u joints on the rear driveshaft but couldnt really tell it they were bad. the one closest to the rear end was pretty hot almost to hot to touch for more than few seconds. i checked the fluid in the rear end and it was to the fill plug. im not sure where to start or how to tell if the u joints are bad. the truck has 87000 miles. thanks for any help
Old Jul 15, 2007 | 08:42 PM
donhov's Avatar
If the rear U-Joint was too hot to touch I'd start there as far as where the problem is. It should not be very hot. When you change it be sure and mark the drive shaft as to where it mounts to the differential. Sometimes if you do not put them back to the same position they were it mayl cause a vibration per prior posts.
Old Jul 15, 2007 | 08:52 PM
bsj04's Avatar
i think im going to start there tomorrow but i didnt know if it would be hot cause the rear end gets hot or something? how hot is the rear end suppose to get?
Old Jul 15, 2007 | 10:35 PM
bsj04's Avatar
i drove the truck a few miles and im pretty sure its the rear u-joint, i felt it again and its only one cap that was hot the rest of the were fine. hope it makes it to work and back tonight before i can fix it tomorrow
Old Jul 15, 2007 | 10:52 PM
blueboy16's Avatar
put your brake and take it out of gear then get a prire bar and try to work it back and fourth i have an 03 and i put ujoent in about every 45000 to 50000 mile i have 160000 mile and on my 3 or 4 ujount back there make sure you heat it with a torch to melt the plactic safty ring dodge put on there or it is real hard to get off
Old Jul 15, 2007 | 10:54 PM
monnshyne's Avatar
If your U-joint is bad then the best thing to do is replace them all with one that has a grease fitting. Would save you alot of headache if another drops while your on the road. I gave less than 25 each for mine in my 05. The dealership wanted 77 and some change each. EEEEEEEEEEEEPPPPPPPP
Amydawn0101
Jun 23, 2010 11:17 AM
twisted1
Jan 13, 2010 02:42 PM
twisted1
Jan 6, 2010 02:30 PM
doorguy
Jun 8, 2007 06:19 AM
