04.5 Antifreeze Petcock broken, leaking
Old Jun 12, 2006 | 01:23 PM
jlipskoc's Avatar
One of my friends can't get his 04.5 cummins drain plug on the radiator to close up properly. He turns it clockwise, he hears a click. And the process starts over.
I haven't seen it, or dealt with it, just over the phone. i'm not sure what to suggest.
Are there threads on that sucker? O-ring lost? Did it break from over torque?
Can you pull it out and replace it with a new one?
Old Jun 13, 2006 | 07:58 PM
H2SRDMB's Avatar
i saw this last night and no-one has replied.. if its the same as my 99. and 2001 it will come out .. i did replace one once on the 99.. i wouldnt trust it unless you ask a raditor shop.. i just did mine and it worked. i had a radiator shop 3 doors down from my shop!! so if it failed no problem.. now if i can get the 2001 to drain.. its striped and just turns and wont drain
good luck keep me posted
bryan
Old Jun 14, 2006 | 08:13 AM
xmr's Avatar
xmr
If his is any thing like the one on my 98 Dakota. You can remove it and change out the O ring and it will cure the leak. I lubed it with some silicone grease then put it back in. I got the O ring from misc. assortment that I bought at a parts store.
Bozy
Nov 21, 2009 05:21 PM
fitzydog
20
Nov 13, 2007 03:50 PM
dodgediesel
Sep 23, 2007 03:27 AM
SmokenRam
May 18, 2006 04:46 PM
Campin Johny
Sep 9, 2003 10:16 AM
