03 Ram bogs down blows white smoke
Old Sep 5, 2007 | 06:05 PM
53 Block King's Avatar
Hey guys... currently driving an early 03 3500 with 220k on her with a 47re. Today I was pulling a 1 ton Ford and the truck bogged down.. almost stalled and blew white smoke, it also smelled like fuel. The truck started running fine after about 3 seconds. I noticed it would only do it under a load or when I would get on it and make it downshift out of overdrive. Driving easy it runs great, up until about 3/4 throttle... ANY IDEAS??? NO CODES or Check engine light. The truck will now do it if you get on it with no trailer... I am confused any help would be awesome!
Thanks Guys!
Old Sep 5, 2007 | 06:08 PM
one more thing.
Truck did have a faulty looking exhause system so I cut it off... it is all straight piped now... it still does the bogging down thing and the white smoke.. till it nearly stalls then it runs perfect again!
Old Sep 5, 2007 | 06:28 PM
vzdude's Avatar
DTR's 'Go to Guy'
Sounds like maybe a week rail relief valve. Losing fuel pressure at high requirement times.
Old Sep 5, 2007 | 10:02 PM
bandit1trucking's Avatar
Check your air filter. Even if the filter minder doesn't indicate a blockage, physically open the air cleaner box, and check the filter. Had the exact same thing happen on an '03.
Old Sep 6, 2007 | 06:49 AM
SAVOY1964's Avatar
Could also be the fuel pump? But mine thru codes when that happened.
Old Sep 6, 2007 | 12:38 PM
bandit... you were right... changed the filter and bingo! Works great... thanks alot!!
Old Sep 6, 2007 | 01:43 PM
Rollin' Smoke's Avatar
that must have been a really dirty filter!
Sthil
Dec 6, 2011 05:18 PM
big_country_001
Nov 30, 2010 07:58 PM
krazydher
May 26, 2009 08:21 PM
joe_yba
Jun 10, 2007 06:49 PM
big bubba
Apr 23, 2006 11:06 PM
