02 motor 99 tranny help
Old Feb 6, 2008 | 10:26 AM
06Wolvy's Avatar
i have a 99 truck and i put in a 02 high output motor. the tranny is still a 99 and the truck will not shift into overdrive. the tranny worked great intel i put in the new motor. the truck will go in overdrive if i haul a heavy load?? but empty no overdrive.
Old Feb 6, 2008 | 11:31 AM
1-2-3's Avatar
Just a plain ole guy
Is the output speed sensor plugged in or damaged on the tranny? My 99 would not go into OD and that was bad. $35 part, 2 minutes labor.
Old Feb 6, 2008 | 01:52 PM
johnh's Avatar
which ecm are you using? the ecm that came with the ho engine wouldn't have the programming for an automatic trans .
maybe i'm up in the night on this, but check it out
i looked in my manual and
i guess i'm up in the night the pcm controls the trans
Old Feb 8, 2008 | 09:15 PM
dozer12216's Avatar
The sensor (gov pres transducer) are different and non interchangable. Just got a beating over this problem. The Lockup, OD sol, and gov pres sol are the same but transducer for pressure and temp are not. Assuming your 2002 had an auto. you need the wiring harness and transducer for inside trans.
Rednecktastic
Dec 18, 2009 08:58 PM
ryan10
Aug 10, 2007 09:38 PM
Common
May 9, 2007 12:11 AM
coupdetat
Feb 17, 2007 12:52 AM
