01 Feels Like Front axle is going to Fall OUT
Old Nov 6, 2008 | 02:46 PM
1stGen72's Avatar
When you realy get on it feels like the whole axle shifts, also when going around turns it feels like sonthing lifts out of place and falls back in.. just put a NEW track bar in and all 4 ball joints. And new tires.
Old Nov 6, 2008 | 07:47 PM
badme's Avatar
Are the control arm bushings good?
Old Nov 7, 2008 | 01:29 PM
mandlbarrett's Avatar
What about your lower steering column bushing? My '99 kind of feels about the same way and my lower bushing is bad. Or loose bolts on steering gear?
Old Nov 7, 2008 | 05:09 PM
ClayBob's Avatar
Might want to check your unitized hub bearing and verify everything is tight. Just a thought.
Old Nov 9, 2008 | 05:03 PM
1stGen72's Avatar
Well it ended up being one of the arms that go from the frame to the axle was bent in.. got it fixed up and working good...
Old Nov 9, 2008 | 05:08 PM
Dinner's Avatar
One of your control arms was bent? Hmmm
Old Nov 10, 2008 | 09:12 AM
Sasqoutch's Avatar
Sounds like someone has been doin alittle off-roadin, hmmmm
chuckybones
Sep 12, 2008 01:54 PM
hamilton71801
Dec 10, 2005 01:15 PM
70DUSTER
May 15, 2003 02:53 PM
gunracer1
May 8, 2003 05:59 AM
