0 psi Injection pressure!?!
I got the dreaded low voltage to the fuel pump relay code, and decided to install a Raptor 150. Now my Rail pressure reads 0. I am running a Quad Commander, and the fuel pressure is fine, the truck runs and drives with no problems, loss of power, anything... I checked for codes, and there are none. What is going on here? Is it safe to drive? Do I need an injection pump now? Getting frustrated and would like help. It is my main tranportation and I need it tomorrow! Thanks in advance.
Last edited by amesff01; Aug 29, 2010 at 07:06 PM. Reason: meant rail pressure, not injection...
Cummins Guru
No way would your truck run with 0 rail pressure. Sounds like your Quad Commander is problem not your fuel pressure. Possible connection problems at fuel pressure sensor. Check your wiring connections.
38 Cigarette
16
Aug 28, 2015 11:27 PM
schamran
Dec 14, 2009 08:20 PM
wap
Jul 30, 2008 07:01 PM
Dave88LX
15
Sep 4, 2006 09:30 PM
ckennedy
Sep 29, 2004 05:06 PM
