will a cummins run upside down?
well, will it? and if it will, how long is safe? 3 minutes? 10 minutes? like if I roll my truck over and need to keep the engine running to use my winch. also will it start upside down?
thanks
Lance
thanks
Lance
yea id say it run upside down but itd be like runnin it with no oil. well then again then unless you had a full tank of fuel the fuel pump would get starved after a time, i think, not sure where the gas tank pump is.
the engine would start and run, but the lube system would not function... if you really fear this roll over thing, just get a pair of BIG batteries and run your winch off them...
Originally Posted by JohnCA58
down under , there are still Cummins out there mounted sideways , we call them pancake engines. and the oil system was design to run that way.
I would be weary about anything more than 45degrees out of it's normal position. While it's no problem to build an engine to run at 90 degrees, the stock oil system won't work. A shurefire sign of troubles coming is no oil pressure. For offroading a good electrical winch and non-spill batteries are the way to go.
AlpineRAM
AlpineRAM
