what valve what years
hey guys, what years were the 12 vale engines and when did the gen 2 24 valvers come along ???? hopefully getting a 24 valver soon considering a couple will do another post 4 your opinions thanks guys,scott<br>
Re:what valve what years
Well, Scott, the 12 valve engines were used from the beginning (1989?) up to 1998.5 when Cummins switched to the 24 valve engine, which is electronically controled. The 2003 engines are still 24 valve, but have other refinements, such as common rail injection. I hope that this answers your question. If you are looking at a 98 Dodge diesel, make sure which engine you have in that truck, because the switch to 24v happened mid-model year.<br><br>Good luck in your search.
With the 24v you also have a higher highway speed without the high rpm. You also dont have to adjust the valves as often. Had both prefer the 24v.
CMN_NOT_STROKN
Nov 22, 2024 02:55 PM
