Sponsored by:
Sponsored by: CARiD
What does the grid heater do?
Old Jan 16, 2004 | 06:52 PM
I have a melted relay on my truck, so the grids are dead. It lit right off at 4 degrees this morning, no grids, just the block heater. Coldest unheated start so far was 15, lit right off, idled lumpy for 10 seconds while laying down white smoke, then cleared right up. I ain't fixin' it, works fine for me without them.
Old Jan 17, 2004 | 11:04 AM
PackRatTDI's Avatar
Originally posted by cp
I thought glow plugs were in the precombustion chamber of IDI heads. I don't know where they're located on direct injection heads. Most DI's don't have them. They heat the air, just like the grid does, only in a different place.
Non-turbo'd diesels generally don't need them so much, as they have higher compression ratios.
The glowplugs in my TDI are located next to the injectors. I've never had to glow more than 10-15 seconds and that was down to -8F in Iowa. If it's above 32 degrees, glowing isn't necessary, it'll fire right up.
VW also incorporated 3 glow plugs into the water outlet to the heater core to aid interior heat. In my A3, you activate them by putting the fan switch on "3" and heat to maximum, air intake to recirc. I've tested it myself, the interior will warm up far quicker that way than turning the fan to "4".
In the newer A4 TDI's (99 and above), they're controlled automatically depending on temperature.
Old Jan 17, 2004 | 12:23 PM
tankeryanker's Avatar
I didn't like the glow plug set up in my 89 ferd 6.9 I had that truck for seven years & seemed like I was always replceing glow plugs.
I love my ctd
SpeedyWS6
15
Feb 2, 2011 07:22 PM
Ramrod90
Feb 3, 2009 07:39 AM
taildragger
Dec 4, 2006 10:00 AM
Katmandu
Feb 24, 2006 01:05 PM
Dodgezilla
Mar 13, 2003 06:14 AM
