Sponsored by:
Sponsored by: CARiD
What is the Difference between Gen #2 and Gen #3
Old Jan 28, 2010 | 05:20 PM
FamilyTruck08's Avatar
I was wondering what the differences were between the Gen 2 and Gen 3 engines. I was also wondering when they went from having the lift pump on the side of the fuel filter to when they put it in the tank.
Old Jan 28, 2010 | 05:49 PM
NoSparkplugs's Avatar
2nd gen engine:
12V with a P7100 mechanical injection pump
-KDP is a known issue
-Lift pump is a mechanical piston style located on the driver's side of the block
-About as reliable as you can get
-Signature 12V sound
-Easy and cheap to bomb and get power out of
2nd gen engine:
-24 valve with a VP44 injection pump
-Louder (some like it, some don't, to each their own)
- Lift pump is on the side of the engine I believe, 2nd gen guys correct me if I'm wrong
-Potential for the 53 block issue
3rd gen engine:
-24 valve with a HPCR fuel injection system
-Quieter than a 2nd gen, early CR trucks have 2 injection events, 04.5'-07' have 3
-3rd gens can take more boost with stock headbolts and gaskets (or so I've been told)
- Dodge did a recall to relocate the lift pump from the filter to the tank in 04 or 05'
I'm sure theres more differences between the three like the blocks, pistons, rods etc.
Old Jan 28, 2010 | 09:42 PM
Tate's Avatar
Some 24v's got the intank lift pump as remedy and as a requirement to get a VP44 under warranty. So its hit and miss if the 24v has an intank pump or a block mounted pump. KDP is also an issue for the 24v's, just not as widely publicized as the 12v's.
Old Feb 1, 2010 | 10:18 AM
Thank you both for the information. That was and is VERY informitive.
TIMMY22
Jan 28, 2010 07:36 PM
D2 Cat
Aug 12, 2009 07:57 AM
Txwelder
Feb 14, 2008 01:02 PM
gman2310
Oct 25, 2006 03:02 PM
SPINPOSI
Aug 24, 2006 10:44 PM
