Want to know your trucks recall repair's
http://www.dodge.com/webselfservice/...m%28%27R%27%29 Just enter your last eight digits of your VIN and it will bring up any open recalls on your truck, Goodluck,,,Rick
I already knew there were outstanding recalls on my truck but never took care of them because the threat of the damage a typical dealer mechanic could do outweighs the damage of letting the recall go. Especially the one involving underdash wiring, I did it myself rather than trust the dealer.
Yea I know what you mean Bill, I did let them do the throttle cable for me and then went straight home and went over everything they did, and had to do some ajusting. Just curious as to what some have had recalled on thier trucks?? Goodluck,,,,Rick
Mine had the auto trans drainback valve, vacuum system overhaul, steering shaft cable tie fix, throttle cable, hood latch, shock coil towers, headlight and blower fan electrical. I only let them do the vacuum system, shock coil towers and AT drain back. While they were doing the drain back they replaced the auto trans lines with the improved connector type. This was a gasser only recall, when I asked why they said they thought mine was gasser. I knew about that time I wasn't going to trust them with my truck. Shock coil supports required welding and the dealer sent it out so I figured that one would be ok.
The throttle cable recall was the result of a massive letter writing campaign to the Highway Safety Transportation Board from the members of TDR.
For comparison my '83 Toyota PU had no recalls in it's entire life.
Re: Doesn't work!!!!!!!
Originally posted by Rammer64
It doesn't work on older generation trucks.
It keeps reading my serial # "is not a valid vin"
Originally posted by TPilaske
I guess this is a good sign:
"No Incomplete Recalls or Customer Satisfaction Notifications Exist"
Tony
Tony
Must be the 2002's are such a fine truck, no recalls have been necessary.
yet.
Give it a year, I'm sure there'll be something.
phox
1st gen vs. 2nd gen
Originally posted by 3KrackerRacing
Dang you had alot recalls!
Might not work on an American site.
None here.
Maybe I finally got a keeper. Seems like all my before dodge ctd I found reasons to not keep. This one 3yrs & I love it as much or more than when it was new.
SECONDARY HOOD LATCH
SAFETY
04/25/2001
INCOMPLETE
REPROGRAM PCM FOR NOX
FED EMIS
10/28/1998
INCOMPLETE
REPROGRAM PCM/ENGINE SPEED
SAFETY
09/28/1998
INCOMPLETE
DEISEL FUEL TUBE
SAFETY
09/10/1998
INCOMPLETE
DC didn't write me a letter. Ship truck as a parcel to the next dealer? ???
AlpineRAM
SAFETY
04/25/2001
INCOMPLETE
FED EMIS
10/28/1998
INCOMPLETE
SAFETY
09/28/1998
INCOMPLETE
DEISEL FUEL TUBE
SAFETY
09/10/1998
INCOMPLETE
AlpineRAM
