Sponsored by:
Sponsored by: CARiD
Two post lift manufacturer?
Old Feb 1, 2013 | 12:41 PM
bironacad's Avatar
I have decided on two post lift for my truck, now which MF (manufacturer)
Model: XPR10 BendPak XPR-10 Two Post Lift
10,000 Lb. Capacity / Clearfloor / Dual-Width
Rotary:
SPOA10X
10,000 lbs. capacity
asymmetrical lift
Any thoughts on these two?The Rotary model is coming in $1000 more.
Old Feb 1, 2013 | 12:47 PM
nkennedy's Avatar
If you put your truck up on a two post life make very sure you have the weight balanced front to back. I saw a truck fall off of one at my neighbor's shop. It pulled the bolts right out of the concrete.
Old Feb 1, 2013 | 12:57 PM
bironacad's Avatar
Did he/she lift it up a little and shake it to see that it was balanced?
Old Feb 1, 2013 | 03:01 PM
jstone44720's Avatar
No negative issues with the Rotary. That is what I use most of the time. I check it by wobbling the truck when it is barely off the ground. Put a tall jack under the hitch for more stability, just don;t forget to take it out prior to lowering the truck.
Old Feb 1, 2013 | 03:51 PM
bironacad's Avatar
I am leaning towards the Bendpak as it is $1000 less expensive, they have a web page showing different comparisons making out the Bendpak as being well built anyone have experience with both?
Old Feb 1, 2013 | 06:27 PM
rattlerbob5.9's Avatar
Both have been in the business a long time, i have an older 10k rotary and a friend has one a few years newer neither one of us has had any problems with them.
Look them over real well, for 1k their has to be something different between them.
Old Feb 1, 2013 | 07:21 PM
j-fox's Avatar
Look up Greg Smith equipment.
I have one of thier 2 post lifts and it has been great.
It is an ATLAS lift.
Old Feb 1, 2013 | 07:38 PM
bironacad's Avatar
I have been looking at threads and saw the atlas but couldn't find a Canadian distributor.
Old Feb 1, 2013 | 07:54 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Oh...Your in Canada...Yes there is no distributor in Canada...I inquired about shipping to the border.....Ow...that was a costly inquire..
Where about in Canada are you?? I got my hoist from LifePro in Calgary..
Old Feb 1, 2013 | 07:59 PM
bironacad's Avatar
Southern Ontario I just looked at Lift Pro what weight category did you go with?
Old Feb 1, 2013 | 08:19 PM
I went a total different route...I didn't have room for a 2 or 4 post...And I only needed it for my collector cars..I had to go with a sissior hoist,which is not good for you...
Remember one thing when buying your 2 post hoist...Really inquire that it is safety certified to at least North America standards...and even better to Canadian safety standard...This is one thing we haven't discussed here..
There are some cheap chinese knock off hoists...that are unsafe and are not certified...If you do a search on the internet of failed hoists,you will see some of these un-certified hoists and how they failed during testing...They where under-rated..
Just a heads up....
BendPak...is a very good product...I think they have a re-seller in Ontario...
Old Feb 1, 2013 | 08:26 PM
bironacad's Avatar
Just a heads up....
Basically looking at the Bendpak and Rotary models for that very reason. My truck is 21' close to 8000 lbs so safety first eh?
Old Feb 1, 2013 | 08:34 PM
Yep...Your on the right track...I researched those to companies for safety standards...And they are good..
A lot of these products are still built in China..But some US firms have stricter quality controls..
Old Feb 1, 2013 | 10:26 PM
torquefan's Avatar
Rotary seems to be considered a top quality hoist, and Bend Pak is a very decent product too. I have used both brands in various shops for years in the past and hadn't seen any problems or breakdowns, and that's with 8 hour/day use (and occasional overloading I'm sure). I don't think you could go wrong with either.
Granted, these were professional grade equipment. Not sure if they make a "consumer/homeowner grade" or not or what the difference in quality may be if they do offer such models.
Old Feb 2, 2013 | 08:48 AM
bironacad's Avatar
I pretty sure that I will go with the Bendpak BendPak XPR-10 Two Post Lift
10,000 Lb. Capacity / Clearfloor / Dual-Width or the BendPak XPR-10A
I don't really know which to go with, the symmetrical or Asymmetrical with the 30 degree twist on the post. Any thoughts there?
