Sponsored by:
Sponsored by: CARiD
School me on Twins
Old Sep 9, 2007 | 10:44 PM
StevenAg03's Avatar
School me on Twins
I dont know much of anything about twins other then there two turbos. can someone explain how they work, why to choose specific turbos, etc, etc? i know turbo selection will probably depend on end use, as does most mods.
hopefully we can get a good thread going and it will be useful for future newbies like me that are curious about twins...
Old Sep 10, 2007 | 12:03 AM
HOHN's Avatar
Twins compress the air in two stages because a single turbo isn't efficient at compressing the air to high ratios. Twins also give you better response for a given amount of airflow.
The air comes into the big turbo, out its compressor and into the small turbo. Then into the engine, out through the small turbo and out the big turbo.
If you want more than that, try searching on my name--I've posted more about them not too long ago.
jh
Old Sep 10, 2007 | 06:32 AM
jrs_dodge_diesel's Avatar
Here is something I have always wondered. Why does the big turbo feed into the smaller turbo? Shouldn't it be the other way around?
Old Sep 10, 2007 | 07:19 AM
RowJ's Avatar
Good question! I thought I knew the answer, but as I started to type I realized I don't. Back to my turbo books in search of the explanation!
RJ
Old Sep 10, 2007 | 07:52 AM
dieselfuelonly's Avatar
DTR question asker
Wait... the big turbo feeds the small turbo?
/grabs hammer
But wait, here is how I thought it works, tell me where I'm wrong:
Small turbo is on the manifold, it gets all the hot air from the engine. The small turbo then blows the air into the big turbo. The big turbo then... wait, that would mean each turbo would have its own intake.
PLEASE HELP ME UNDERSTAND!!!
Old Sep 10, 2007 | 08:07 AM
AlpineRAM's Avatar
Because the small one won't flow the required mass without positive pressure on it's intake
Old Sep 10, 2007 | 08:57 AM
RowJ's Avatar
Cool Air flows from air filter.... to big (bottom) turbo ...... to small turbo...... to engine.
Hot Exhaust Air flows from engine..... to small turbo.... to big turbo.... to exhaust pipe.
Help any?
RJ
Old Sep 10, 2007 | 09:23 AM
DTR question asker
That does, thanks!
Old Sep 10, 2007 | 10:17 AM
74dart's Avatar
So how does it work if you have a HT3B that spins backwards?
Old Sep 10, 2007 | 03:01 PM
pmtg's Avatar
the position/orientation of the turbo might be different, but the air still travels from air filter to big turbo (whether it spins 'forwards' or 'backwards') then to little turbo to engine. the exhaust still goes from engine to small turbo to big turbo to tailpipe.
Old Sep 10, 2007 | 07:31 PM
74dart's Avatar
Ok so the next question. What changes have to be made to a s300 turbo so they will fit these trucks. Just wondering what makes them so expensive.
Old Sep 10, 2007 | 08:05 PM
97ramctd's Avatar
ok now that i understand, time to start fabing
Old Sep 11, 2007 | 05:42 AM
74dart's Avatar
When setting up a set of B1 B2 tiwins. Where do you get the small stuff like the cold pipe that connects to the s400 output the bands to connect the exaust, a gaskett for the botom turbo, and the oil return hose for the bottom turbo? I know most of the cold pipe is exaust tubing welded together I have that part covered and I also can build the hot pipe.
Old Sep 12, 2007 | 08:05 PM
jfranklin's Avatar
get your hands on a set of twins that some one already has working and copy them. you will most likely find the kits are expensive but worth it.
Old Sep 12, 2007 | 08:07 PM
jfranklin's Avatar
try this website www.sourceautomotive.biz
