Sponsored by:
Sponsored by: CARiD
Remote Racor Fuel Filter Question
Old Mar 11, 2005 | 08:29 PM
fishin fever's Avatar
Hi All; Well lets start by saying I'm rather sound stupid to people on the forum who don't know me,and have my question answered for free then to look stupid in front of a diesel mechanic and pay too have question fixed My truck has a remote racor fuel filter..big sucker the size of a 48 oz juice can[ok not as big but close] between the pump and battery nice and high and easy to get at..... heres the problem how to drain water this one has a bowl on the bottom with a drain line but no[to me ] visable way to open it ..the top or they call it the head has primer pump which is a good thing i think... the instuctions on it say "to prime open release valve and pump that i belive is a7/16 nut in the fitting for the line goin to the old pump location.... to drain open drain valve and pump..... the filter says open valve and drain or if eqip with primer /relief valve hold in while pumping water out ......well theres nothin to hold in just the pump thing anyway somebody must have one of these help ps maybe just the filter is racor not the unit????
Old Mar 11, 2005 | 11:06 PM
OK this may help after checking racor site I'm pretty sure its a 400 series model 490 which on there break down pics shows it as self draining???
Old Mar 12, 2005 | 06:56 PM
Sorry, my work truck has a Davco and it's different than the Racor. You might want to ask a moderator to move this to general diesel where more of the guys with big-truck knowledge will see it.
Old Mar 12, 2005 | 11:04 PM
Thanks Dave, I'll do that now.
Old Mar 13, 2005 | 02:27 PM
jive55's Avatar
Racor
Fishin' fever : my Racor 225R has a valve at the bottom of the bowl. Has yours been plugged or is there nothing there period.? I've always had a gallon can with fresh diesel in it when I change mine. Just drop the bowl, clean it out. Replace filter (?) then before screwing bowl back on fill it a bit with diesel and install. The hand pump tops it off. You can start it actually without hand pumping it but it'll blubber for awhile until the filter gets pressurized.
Old Mar 14, 2005 | 11:44 PM
Hey Jive 55 thanks for reply but no valve on bottom [just drain and water sensor lead]... from the racor website I'm almost posstive its a 400 series they have the pump on top and best quess from the 3 choices is the 490 info says self draining on the web but as stated on post conflicts with the head instuctions which conflict with the filter instructions so i'm confused Have requested tread be moved to general site but .......no go
Old Jan 17, 2006 | 03:26 PM
vrj's Avatar
vrj
Originally Posted by fishin fever
...the instuctions on it say "to prime open release valve and pump...
On the 445/460/490 models (Raycor) with the priming pump, the bleed valve is on the right output port. Just loosen the bolt and push the primer until fuel begins to exit the port then close the port. The filter is now primed.
M1Lover
Jul 17, 2008 03:26 AM
fishin fever
Mar 15, 2005 11:45 PM
ratsun
Jun 6, 2004 01:49 PM
yomitch
Nov 18, 2002 01:33 AM
