Sponsored by:
Sponsored by: CARiD
PTO Questions
Old Sep 27, 2005 | 12:32 PM
Mark Hodowanec's Avatar
PTO Questions
I have a 2004.5 w/ the Cummins & a six speed manual transmission(NV5600). There is no high idle on this truck because there is no clutch neutral switch. I have a couple of general PTO questions:
What is the most Hp that can be pulled thru the PTO
What is the gear tooth count or how can I figure out what output speed thru the PTO gear will be.
How can I control the idle speed - will a 2x4 & power seat work? How accurate will the speed regulation be (want to hook up a generator)?
What kind of motor speed do I need to genarate 13 kW (20 HP)?
Old Sep 27, 2005 | 03:27 PM
MikeyB's Avatar
This might help with some of the info. http://www.parker.com/chelsea/old/Pr...pto_charts.htm
For the generator part, will be a AC type? If so you would need a hertz meter to set the rpms to match 60 hertz. I did this on a Dayton PTO AC generator.
I think Genos Garage has a adjustable throttle control stick that slips between the steering wheel or seat to the peddle and can be fine tuned.
MikeyB
Old Sep 27, 2005 | 04:16 PM
nickleinonen's Avatar
there is a pto program built into the ecm, and there is a pin on the ecm that needs to get a signal to activate the pto function... it is listed in the wiring schematics, but i don't think anyone has figured out how it functions yet... [i am still researching it too..]
Old Sep 27, 2005 | 05:48 PM
MikeyB's Avatar
Might want to contact this company for the electronic throttle control.
http://www.vmac.ca/throttle/
MikeyB
Old Sep 29, 2005 | 08:58 AM
Tried them - same reply as anyone else with an idle up controller - "not for 2003 - 2004 dodge 6 speeds". Again, dodge left out the neutral switch & to cover their liability made it next to impossible to get at the ECM to turn on this feature. Aftermarket companies are struggling because of the same issue. I have a question e-mailed to the dodge body builder group asking them how the **** they expect me to use PTO. Just got a responce that "someone is working on a responce for me".
Mark Hodowanec
Apr 7, 2005 09:01 PM
BDude555
Feb 24, 2004 06:49 PM
Haulin_in_Dixie
Oct 16, 2003 11:43 AM
ARAcummins
Feb 26, 2003 03:45 AM
Palmetto_kid
Oct 16, 2002 05:41 PM
