Sponsored by:
Sponsored by: CARiD
Powerstoke wont start
Old Sep 24, 2005 | 03:43 PM
Hillbilly_Deluxe's Avatar
Well she won't start now. No haven't got around to the glow plugs or thermostat in it yet but i was wondering what a way to get her goin would be. I've heard of pouring water over the pump will that warm it up enough to start it?
Old Sep 24, 2005 | 04:30 PM
Never mind block heater worked.
Old Sep 24, 2005 | 07:00 PM
TxDiesel007's Avatar
Just a quick question
are you SURE that your 1990 is not a 7.3 IDI? did you plant in the powerstroke? Simple analysis, if it dont have a turbo and has an aircleaner up top, one of those round ones, you are looking at a 7.3 idi.
If that is the case then proceed with looking at all of these ideas.. If it is a powerstroke for sure (which i doubt but can be wrong) then disregard the rest of this post
Check
Glow plugs
Glow Plug connectors
Glow plug relay been replaced? how old is it?
Fuel lines, check the little caps that go over the injectors and the rubber lines
Injector pump, how old is it? if its original and truck is over 150K chances are you need a new one.....
Lift pump, for 20 bucks and lesst han an hour of work, cant go wrong with replacing this one.
batteries, how good are they, do they hold a charge
alternator
starter..
Try checking all of those, if all is well, chances are your IP is going south..
Tx
Old Sep 24, 2005 | 07:01 PM
Well my analysis was correct here..
You DO HAVE an IDI (indirect inject) pouring water over the pump is supposed to cool it off sufficiently to actually restart the truck, but if that isnot working, your IP needs to be replaced...
Tx
Old Sep 24, 2005 | 07:57 PM
bmoeller's Avatar
If pouring water on the pump works to help start it, check the shutoff solenoid. I know they can get hot and quit working for a while.
Old Sep 24, 2005 | 10:20 PM
JKM's Avatar
JKM
It won't start because it is TOO cold , pouring water on it to cool it off won't help.
MTGunNut
Aug 16, 2006 02:33 AM
Thenewguy
Jul 21, 2006 04:04 PM
SmokinDodge12V
Competition / Pulls / OffRoad
51
Jan 10, 2006 05:42 PM
Dr. Evil
Aug 11, 2003 08:45 AM
DieselDaze
Aug 10, 2003 09:58 PM
