OT: Detroit V8-92 Low Oil Pressure
I have an issue that I am unsure of, hopefully someone in these forums have seen this before & shed a little light on the situation. The engine is a Detroit V8-92 Diesel engine that show very low if any oil pressure @ an idle (15 psi or less). This reading is coming from the mechanical gauge on the dash & the panel (its a fire truck). When the rpm's climb, so does the oil pressure, which doen't bother me. But my question is, do these engines have a tendancy to run low on pressure @ an idle? What can cause this?
The oil pressure gauge on a Detroit always reminded me of a tach.
We have an old 4-71 at work that is hooked to a water pump, when shutting it down I bring it down to idle for a bit and it reads a little less than 5 lbs.
Been that way for years. The thing doesn't get used much, sits for months but always starts right up. It uses lots of oil
We have an old 4-71 at work that is hooked to a water pump, when shutting it down I bring it down to idle for a bit and it reads a little less than 5 lbs. Been that way for years. The thing doesn't get used much, sits for months but always starts right up. It uses lots of oil
2-stroke engines use more lubrication oil (slobbering)
chuckysback55
Mar 15, 2011 10:40 PM
jogl
Oct 17, 2008 08:12 PM
GlennRMK
May 24, 2007 10:46 PM
Power Ram 250 C
Feb 20, 2007 11:08 AM
