Oilfield MythBuster
Oilfield MythBuster
Any of you tong throwin' roughnecks ever had a truck keep running after it was shut off due to high levels of natural gas in the air out in the field? I have heard many stories......
Mark
Mark
My brother in law was running a D7 Cat. He hit a natural gas line. The motor took off, he tried shutting it off even rapped his coat around the intake. The motor revved so high it broke.
This explains it well.
http://www.amotusa.com/Z_Dead%20Datasheets/4261.asp
I have one on my truck, legislated for me to work on sites in the province of Alberta.
IF you don't believe it, check out the news for that huge refinery explosion in Houston last year. It levelled a few blocks of process equipment and was all sourced back to a Ford Service truck parked near a vessel that ran away.
BOOM....
I don't recall if there were fatalities or not.
BOOM....
I've seen runaways with the hummers we use... Smothered air, cut fuel, punched holes in the oil pan... nothin. I think that if we took the oil away faster it would have stopped, but I'm not sure. Hard to stop these Cummins when they want to run. Bout the only thing that I know of that will stop them is a fire extuingusher in the intake.
I've also heard of trucks starting by themselves from people who *claim* to have witnessed it first hand. Sounds a little far-fetched to me, but I suppose if conditions were absolutely perfect it may be possible.
That's a good question. I cannot see it hapening, unless someone left the ignition on and the truck started rolling in gear...??? Not unless there was some MAD static electricty that jumped the starter....???
