Sponsored by:
Sponsored by: CARiD
Number one diesel
Old Sep 12, 2004 | 10:01 AM
DSjockey's Avatar
Number one diesel
Searched but couldn't find anything (that 3 word min makes it a PITA sometimes) Read some previous dussion that there was no problem running #1, that was what was around last night so I filled up with it (was +.03 from truck stop accross town) I noticed a big difference in smoke right away (not a bad thing when in town) my question is should I be adding a fuel treatment for lubricity (sp?) if running this fuel TIA
Old Sep 12, 2004 | 10:30 AM
CTDinMT's Avatar
Yes- If you are running #1, you should most definately put some Stanadyne/PowerService, etc.. because #1 will not lubricate your VP44 as well as #2. You will probably notice a drop in your MPG also. -Steve
Old Sep 12, 2004 | 11:16 AM
Lightman's Avatar
Diesel #1 is essentially the same thing as Kerosene. It's only typically to be used to cut #2 down in the winter in respect to gel points. It has less power(btu's) per gallon so your mileage and HP will suffer. It also has less lubricity as mentioned above, so I would recommend adding a lubricity additive pronto. Biodiesel would work really well!
Old Sep 12, 2004 | 11:38 AM
tankeryanker's Avatar
Lightman said it all. We blend #1 d/o for winter blend as we are loading at the pipeline. Depending on how cold it gets as to the % . The only time I load straight load of # 1 (kerosene) is for heating oil stored at our bulk plant & distributed by our local bob tail drivers. I would use straight #1 in a pinch to get me home but would not put it in my truck purposely.
Old Sep 12, 2004 | 01:36 PM
DSjockey's Avatar
Thanks guys, got some Power Service additive and putting it in on the heavy side, I'll run it down to 1/2 tank or so and fill back up with #2
by2005
Sep 1, 2006 10:12 AM
Hoss
Oct 28, 2005 10:02 PM
csramsey640
Sep 11, 2005 07:09 PM
Bushy
Jul 16, 2005 01:50 PM
