Sponsored by:
Sponsored by: CARiD
New Ford Commercials-I had to laugh!!
Old Feb 2, 2007 | 12:09 AM
fbx22's Avatar
Originally Posted by mj007
Geez, that never stopped Ford from shipping them out before Maybe the car-haulers are using Fords too!
Old Feb 2, 2007 | 12:14 AM
i6DZUL's Avatar
Originally Posted by lgp9999
Speaking of commercials, am I the only one that hates that Ford commercial with the guy pulling the semi truck out who's stuck in the tunnel so that the ambulance can get through? I mean, sure, if the semi can't push itself out of the tunnel, then the pickup is sure going to be able to pull it out.
I've seen that one a couple times and upon closer examination, I came to the conclusion that the semi is pushing the ford out of the way.
Old Feb 2, 2007 | 07:46 AM
Mcmopar's Avatar
Originally Posted by rollinsmoke
No i haven't seen them what station you guys been watchin?
I saw the first one on NBC
Old Feb 2, 2007 | 10:22 AM
SOhappy's Avatar
Get used to it, I read somewhere there will be a couple of Furd Truck SuperBowl commercials this year.
Old Feb 2, 2007 | 01:14 PM
johnny5.9's Avatar
Talking
Does anyone else see something wrong with Ford going to compound turbos but retaining their garbage VG turbo? Since the VG turbo surged really bad before why keep it? If you're running compounds why would you want a VG in there anyway, you shouldn't need it. It's just more repair expense when something breaks(which you know it will). Also, I hope they have different head gaskets on the new ones because if they couldn't take the single turbo they sure aren't going to like the compounds.
With the way the powerstrokes run it's no wonder Ford makes front tow hooks standard equipment.
Old Feb 2, 2007 | 01:42 PM
HOHN's Avatar
Emissions, plain and simple. The twins allow a lower temp in the hat, which reduces NOx. Also, better spoolup. These turbos are NOT the same as the 6.0 was.
The "small" turbo is quite a bit smaller.
We take a turbo from a class 8 and install it as a big turbo to enhance airflow potential (and hence hp support). You could just as easily take a stock CTD turb and install it on a Class 8 as the "small" turbo to eliminate the black smoke that many large trucks have when the first take off.
The latter is similar to the emissions strategy that Ford and others are employing.
jh
DrBoost
Nov 28, 2007 10:36 PM
LanceD
Aug 29, 2006 08:06 PM
Homestead
Mar 18, 2006 05:34 PM
DrJeff
May 2, 2004 07:53 PM
