Sponsored by:
Sponsored by: CARiD
More Power For Motorhome
Old Aug 3, 2008 | 09:45 AM
Tobin's Avatar
A friend of mine just purchased a 2001 ish motorhome with a 5.9 Cummins (VP44 pump) and a Allison auto. What will work to give it some more power? I have not seen the motorhome, I figured they probably don't even have OBDII ports on them. Can Cummins just reprogram the ECM?
Thanks,
Tobin
Old Aug 3, 2008 | 11:06 AM
DiezelSmoke's Avatar
It will have an OBII port on it.
Old Aug 4, 2008 | 08:26 PM
Tobin's Avatar
So what can we do for more power?
Tobin
Old Aug 4, 2008 | 08:37 PM
scottsjeeprolet's Avatar
I'm pretty sure Edge or BD makes a chip for them. Go check out their web sites.
Old Aug 4, 2008 | 08:39 PM
Diesel Doc's Avatar
Cummins should have a rv tune for it if it doesn't have it in it already. You need to know what operating system it is running. Is it a dodge motorhome?
Old Aug 5, 2008 | 07:13 PM
Hvytrkmech's Avatar
If it has an ISB in it, then it is most likely a small pusher. That means it is most likely built on a class 6 Work Horse chassis and is not required to be OBDII compliant. It most likely has a 6 or 8 pin duetch connector located either on the left driver side kick panel, or in the engine compartment.
Call these guy's, they are very good.
http://www.dieselinjection.net/frames.html
Tim
Old Aug 14, 2008 | 06:58 AM
Tobin's Avatar
Its a Spartan chassis.
Anyone have these things hopped up?
Tobin
Old Aug 14, 2008 | 10:10 PM
HOHN's Avatar
Try some RV injectors.
Just kidding-- I'd recommend larger injectors from F1. Some Mach 2s should work well.
high country
Mar 4, 2005 08:35 PM
cumminsdriver635
Feb 15, 2005 02:30 PM
spunbearing
Jul 28, 2004 10:08 AM
wannadiesel
Sep 18, 2003 05:59 PM
gyroite
Jun 11, 2003 09:24 AM
