Sponsored by:
Sponsored by: CARiD
MB Diesel
Old Jan 14, 2004 | 03:00 PM
DieselDaze's Avatar
MB Diesel
This sure has some impressive numbers:
MB Diesel Link
Technical Data 906 926
Number of cylinders 6/in-line 6/in-line
Bore 4.02 in (102.0 mm) 4.17 in (106 mm)
Stroke 5.12 in (130.0 mm) 5.35 in (136 mm)
Displacement 388 cu in (6.37 liters) 439 cu in (7.2 liters)
Weight 1235 lbs (560 kg) 1235 lbs (560 kg)
Engine Performance
906
190 HP @ 2200 RPM 520 lb•ft@ 1200-1600 RPM
210 HP @ 2200 RPM 520 lb•ft@ 1200-1600 RPM
210 HP @ 2200 RPM 605 lb•ft@ 1200-1600 RPM
230 HP @ 2200 RPM 660 lb•ft@ 1200-1600 RPM
250 HP @ 2200 RPM 660 lb•ft@ 1200-1600 RPM
260 HP @ 2200 RPM 700 lb•ft@ 1200-1600 RPM
926
250 HP @ 2200 RPM 800 lb•ft@ 1300-1600 RPM
280 HP @ 2200 RPM 800 lb•ft@ 1300-1600 RPM
300 HP @ 2200 RPM 860 lb•ft@ 1300-1600 RPM
330 HP @ 2200 RPM 1000 lb•ft@ 1300-1600 RPM
Rich
Old Jan 14, 2004 | 03:05 PM
Rusty69's Avatar
I just wish I could afford one...........
Old Jan 14, 2004 | 03:07 PM
DieselDaze's Avatar
I wonder how well that would fit into the front of my wifes Suburban?
Rich
Old Jan 14, 2004 | 04:38 PM
Those are a little too big for a pickup truck, but there's a 4 cylinder version of the smaller one that could work. It has a real engine brake, too. I think people would complain about rough idle, though.
Old Jan 14, 2004 | 04:50 PM
DieselDaze's Avatar
According to the pdf file:
Application
6-cylinder diesel engine with rated output and torque that’s ideal for use in medium-duty truck
applications such as pick-up and delivery, expedited freight, beverage distribution, utility, recreational
vehicle, refuse, fire and emergency service and many other applications.
So, it looks like they're targeting the pick up market.
Rich
Old Jan 14, 2004 | 04:54 PM
"Pick-up and delivery " is trucking industry jargon for what UPS guys do.
Old Jan 14, 2004 | 05:02 PM
DieselDaze's Avatar
Doh!
Your right, I did not read it that close.
Sorry about that.
Rich
tfarmer96
May 4, 2005 09:59 AM
JoeDiesel
Mar 18, 2003 06:24 PM
