Sponsored by:
Sponsored by: CARiD
Marvel Mystry Oil
Old Dec 2, 2006 | 12:01 PM
dart4forte's Avatar
Marvel Mystry Oil
Who uses Marvel Mystry Oil?
Old Dec 2, 2006 | 12:16 PM
sixshooter's Avatar
I started when they put the notices for the new ultra low sulphur on the pumps.
Old Dec 2, 2006 | 01:08 PM
gmctd's Avatar
Why not use two-stroke outboard motor oil - it is formulated for combustion chamber service.
Cheaper, ain't red, and burns clean - what more could you ask?
16oz\35gal tank
Try it - you'll like it..............
Old Dec 2, 2006 | 01:16 PM
zfort001's Avatar
Marvel is not the best since it thins the diesel even more. If you read the MSDS for it, its mostly solvents and naptha (lighter fluid) i realy dont want my diesel even thinner than it is.
Old Dec 2, 2006 | 03:35 PM
timcasbolt's Avatar
I put 8 oz. MMO every fill up. It's an excellent lubricant. Tried same amount of 2-cycle oil, but it seemed to smoke a little more when leaning on it.
Old Dec 2, 2006 | 03:45 PM
Cmullen's Avatar
Who's 2 cycle oil di you use,,those little cans are expensive and not very much in there??
Old Dec 2, 2006 | 04:06 PM
Mopar440_6's Avatar
I use Marvel in my gas engines (lawnmower, motorcycle, '41 Plymouth) once in a while just to clean them out. The stuff works GREAT for loosening tight engine parts. I had a 1976 Honda motorcycle that hadn't been run in 20 years and poured about 2oz of MMO into the chamber and it fired right up after the fuel was cleaned. Now I would never use MMO in a diesel engine. I'll stick with Power Service or Red Line Lubricants diesel additives for the Cummins...
Old Dec 2, 2006 | 04:09 PM
nelrod's Avatar
Wally World has a TCW3(Asheless 2-stroke oil) for about 8 bux/gallon. I put about a quart to 35 gallons. That's still only about 140:1 ratio
Old Dec 2, 2006 | 04:35 PM
gmctd's Avatar
Two-stroke oil comes in the little cans for weed-eaters, also quarts and gallons - walton's is a good source, any auto parts emporium.
You don't need any detergents, varnish-removers, lifter cleaners, spark-plug cleaners, etc - just an ashless lubricant for the Inj Pump that will combust easily.
Old Dec 2, 2006 | 05:00 PM
HorseHauler's Avatar
this is the first i've ever heard of "i would never put MMO in a diesel engine"?? I've heard now for 3 years on this forum to use it, probably over 75% of the members here do the ps/mmo mix....
Old Dec 2, 2006 | 08:16 PM
sixshooter's Avatar
I read where some of the members are using acetone in their diesel, I would sure think that would be more of a hazard from thinning the diesel than MMO.
Old Dec 2, 2006 | 10:10 PM
wiskeyVI's Avatar
I've usedMMO in gassers for years.
What would be the reason to use 2 cy oil in the fuel???
Old Dec 2, 2006 | 10:20 PM
Sharx Ram's Avatar
I use 16oz. of Power Service Diesel and 8oz of Marvel Mystery Oil..works great and helps with fuel milage also.
Old Dec 2, 2006 | 11:02 PM
garretch's Avatar
anyone ever hafta explain red diesel from MMO to the cops?
Old Dec 2, 2006 | 11:05 PM
sixshooter's Avatar
I doubt that a bottle of Marvel will show up in 30 gallons of diesel. Maybe I am wrong.
