Lock your tank!
Haven't used the primer button in over a decade.
So are you saying your anti-rollover valve ball is missing? was it removed or punched into the tank?
If it was punched down the neck I would think it would lodge somewhere in the filler neck.
You could easily MIG an electrical "reducer" washers or a disk of expanded metal of to the end of the filler neck to prevent anything from entering the tank, I would engineer it as to not too restrictive for when I am refueling.
I would set up a camera and booty-trap the tank.
Jim
Jim
I have been thinking similar for a fix. Will try to fix soon. Truck has been running good so no damage done other the filler neck.
I am going to look for a camera before heading down there again. I also have a booby-trap in mind too.
As I recall my anti rollover protection had an inner door that you push open with the fuel nozzle. I don't think it was pushed in as they would not be able to get a hose down. The pipe appears clear all the way down to the tank. I will have to check it better. I believe the whole guts was removed. Not sure how that was done.
Get us a picture of it when you get the chance.
I knew a person who had a Class-A motorhome and he had his fuel stolen so he somehow connected his fill pipe to the black holding tank, he found the hose, cans and trails of vomit leading from the side of the bus.
There are always ways to protect your property.
Jim
I'm telling you guys right now...
A locking fuel cap will not stop anyone from getting your fuel. You're better off alarming your truck, or sleeping in the bushes next to it. If they can't siphon it, they're going to drill it, and then you're replacing a tank.
http://www.ocala.com/article/2012040...CLES/120409982
Better off letting them siphon it
xp8103
Jun 2, 2006 07:00 AM
mr T
21
Jun 1, 2005 08:48 AM
damon_achey
Jun 7, 2004 03:33 PM
