Sponsored by:
Sponsored by: CARiD
Just a thought.
Old Aug 22, 2007 | 07:08 PM
tuzlo's Avatar
Just a thought.
Does the computer measure essential paramaters like EGT, Tranny temp, boost, etc etc. If so does anyone know if they can be extracted through the OBD-2 port. I know VW and some other vehicles can interface a laptop to the port and extract info when the car is off as well as track information, performance paramaters, through the OBD-2 port. Just a Thought.
Old Aug 22, 2007 | 07:23 PM
vzdude's Avatar
DTR's 'Go to Guy'
Trans temp yes, but EGT no. Boost yes, but their base starts at 14psi (some models start at 0 depends on years) because of barometric pressure. Coolant temp yes, there are several hundred things they monitor. Unfortunately getting that info from the OBDII port #1 is kind of expensive for the programming and #2 not 100% real time. The ECM determines which parameters are "important" and they are only updated to the OBDII port at certain intervals. You may actually be seeing old info from the ECM.
Gary C
Nov 4, 2004 10:02 PM
shortround
Jun 16, 2003 08:58 PM
acoustic_axe
May 25, 2003 08:52 PM
dodgeram
Nov 9, 2002 10:49 AM
